Local Time 10:57 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : circuitgizmos site not accessible, need firmware info
Mindwarp
Posted: 04:45am 26 Jun 2022
Anyone have the guide on updating the firmware on the retromax?
hitsware2
Posted: 03:10pm 26 Jun 2022
This won't do it ?
https://geoffg.net/Downloads/Maximite/Colour_Maximite_2_MMBasic.zip
Edited 2022-06-27 01:13 by hitsware2
my site
Mindwarp
Posted: 04:18pm 26 Jun 2022
Hi hitsware, thanks for the response. I have those docs however the steps refer to "PGM" pins, those pins are not on the retromax. The board does have J65-J67 near J18 which is labelled Firmware reflash. I need to know which pins to jumper.
Posted: 04:23pm 26 Jun 2022
command "UPDATE FIRMWARE"?
CircuitGizmos
Posted: 04:39pm 26 Jun 2022
ALL of my websites and email are down. I'm fighting to get back on line.
The RetroMax has a firmware update button that can be pressed on powerup to put the device into firmware update mode.
See this:
Reloading_Firmware.pdf
Mindwarp
Posted: 04:07am 27 Jun 2022
Thank you CG for taking the time to respond while you are dealing with your sites, it's very much appreciated! The firmware process worked like a charm, I'm now on v5.07.01.
Edited 2022-06-27 14:08 by Mindwarp
