Local Time 04:04 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite ADC Issues ?
bigfix
Posted: 01:56pm 23 Jun 2022
I stepped over this by accident - maybe interesting
Matthias built a Gamma Ray Spectrocop with an Pico and found some inconsistencies in the aquired data.
DIY Gamma Spectrocsope
He found an investigation about some design flaws of the RP2040 ADC from Mark Omo
Characterizing the Pico ADC
Mark did some detailed measuring and found that some capacitor values in the chip are slightly off, causing nonlinear behaviour
Pico ADC Nonlinearity
Mark also found some interesting facts about the Low Noise PS for the ADC
PSU Noise
Edited 2022-06-24 00:00 by bigfix
Posted: 02:09pm 23 Jun 2022
Hi bigfix,
Thank you for the information. This topic has been discussed here already, most of it is over 1 year old. But it is always good to be reminded there is still a design flaw in the RP2040.
It might already have been fixed....?
Amnesie
Posted: 04:14pm 23 Jun 2022
  Quote  It might already have been fixed....?
No it isn't fixed and is even documented in the offical Pico datasheet.
If I can get aways with a tiny bit more processing time due to the i2c protocol, I use the even better external ADS1115 I2C ADC.
Greetings
Daniel
Edited 2022-06-24 02:15 by Amnesie
