Local Time 11:31 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WS2812 addressing
Tinine
Posted: 12:37pm 23 Jun 2022
This just seems to be a very cool way to chip-select. Must be a device out there that does this but I havent found it
Craig
chuckallisonusa
Posted: 12:44pm 23 Jun 2022
The ws2812 works in the order it is connected. If you want a certain spot the whole chain is populated with information for blanks until the one you want. If you 8 in a chain you need 8 data sets.
Posted: 12:52pm 23 Jun 2022
Each WS2812 has 3 shift registers in series, for Red, Green and Blue. As you clock bits in on the input they are clocked out on the output. As each register is 8 bits long you have to clock 24 bits for each WS2812 in the chain. That's why you need to know how many there are - you simply re-write the entire chain to change a single bit because it's actually a single flippin' big shift register.
Tinine
Posted: 01:17pm 23 Jun 2022
Oh I get it but I'm just thinking of the on/off aspect. Imagining a string of addressable opto-couplers, SSRs etc., driven by a single output.
Craig
