Local Time 04:04 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Warp speed PicoMite
Posted: 02:57pm 20 Jun 2022
Bleep (Kevin Moore) has discovered how to underclock the flash memory on the RP2040 at boot allowing the system clock to run faster while still reliably reading the flash. I've then worked out how to make this flexible depending on the CPU speed.
Together these mean that we can now clock the PicoMite and PicoMiteVGA at up to 378MHz.
Testing the PicoMite at this speed I'm now seeing The simple speedtest showing more than 257,000 basic lines a second and grainbench at 6441
I've attached the files below for testing - please let me know if you see any issues on any peripherals (I2C, SPI, PWM, etc.)
PicoMite_Beta.zip
Edited 2022-06-21 01:00 by matherp
Posted: 03:20pm 20 Jun 2022
Just because it happens to be what I'm doing right now, reading of 10 DS18B20 sensors at a gulp, with timer in seconds:
> AUTOSAVE
' DS18B20x10.bas
Dim string s: Timer =0
 Print Fix(Timer/1000);
 s=Str$(TEMPR(9))+" "+Str$(TEMPR(10))+" "+Str$(TEMPR(11))+" "+Str$(TEMPR(12))+" "+Str$(TEMPR(14))+" "+Str$(TEMPR(15))
 s=s+" "+Str$(TEMPR(34))+" "+Str$(TEMPR(32))+" "+Str$(TEMPR(31))+" "+Str$(TEMPR(29))
 Print "! "+s
 TEMPR START 9,3:TEMPR START 10,3:TEMPR START 11,3:TEMPR START 12,3:TEMPR START 14,3:TEMPR START 15,3
 TEMPR START 34,3:TEMPR START 32,3:TEMPR START 31,3:TEMPR START 29,3
 Pause 1000
Loop
Saved 303 bytes
> run
0! 25.125 28.25 25.75 27 23 27.75 24.375 25.625 25 25.4375
3! 28.0625 27.9375 25.9375 27.25 23 27.875 22.6875 24.1875 23.5625 23.875
4! 28.125 27.9375 25.9375 27.25 23 27.9375 22.75 24.125 23.625 23.875
5! 28.125 28 25.9375 27.25 23 27.9375 22.75 24.1875 23.625 23.9375
6! 28.125 28 25.9375 27.25 23 27.9375 22.75 24.1875 23.6875 23.875
7! 28.125 28 26 27.25 23.0625 27.9375 22.75 24.25 23.625 23.9375
> ?mm.device$,mm.ver
PicoMite         5.07051
Posted: 03:43pm 20 Jun 2022
Something now fubar with sub-directories:
PicoMiteVGA MMBasic Version 5.07.05b10
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> option list
OPTION KEYBOARD UK
OPTION SDCARD GP13, GP11, GP12, GP10
OPTION AUDIO GP6,GP7, ON PWM CHANNEL 3
> ? MM.Device$
PicoMiteVGA
> ?MM.Ver
5.07051
> files
A:
  <DIR>  basic-challenge
  <DIR>  cmm2-welcome
  <DIR>  forth
  <DIR>  kingdom
  <DIR>  mick
  <DIR>  mmbasic-lazer-cycle
  <DIR>  picomite-vga
  <DIR>  polar-snake
  <DIR>  saaint-private
  <DIR>  saaint-public
  <DIR>  scratch
  <DIR>  sptools
  <DIR>  tmp
  <DIR>  welcome
  <DIR>  zmim
04:33 01-01-2000        158  bug.bas
00:39 01-01-2000         31  foo
00:17 01-01-2000         32  foo.BAS
00:02 01-01-2000        161  key-bug.bas
00:13 01-01-2000       1095  LICENSE.BAS
05:44 01-01-2000       5193  manual_serial.bas
04:32 01-01-2000       1192  receive-bug.bas
00:11 01-01-2000       2016  receive.bas
03:51 01-01-2000       1906  transmit.bas
01:45 01-01-2000        316  transmit_simple.bas
15 directories, 10 files
> chdir "tmp"
> files
A:tmp
Error : Could not find the path
Posted: 04:42pm 20 Jun 2022
  Quote  Something now fubar with sub-directories:
I updated FatFS to the latest and it seems to have broken something - will backout/investigate
Posted: 05:23pm 20 Jun 2022
Back to the old FatFS
PicoMite_Beta.zip
Posted: 06:06pm 20 Jun 2022
  matherp said  Back to the old FatFS
Thanks, that seems to fix the directory issue.
The performance improvement is very impressive.
On a probably unrelated issue I am having some problems with poor keyboard responsiveness which I suspect may be related to playing my multi-channel "The Entertainer" music - it seems to be fine the first time round and then very poor the second. This however may predate today's updates as I've not really been using the PicoMite much (I've been using MMB4W as a proxy). There are however quite a few other moving parts to the game/program that's playing the music so more information when I have time to pin down the actual problem area.
Edited 2022-06-21 04:12 by thwill
Bleep
Posted: 06:30pm 20 Jun 2022
Hi Lizby,
in the manual it says:-
0 = 0.5ēC resolution, 100ms conversion time.
1 = 0.25ēC resolution, 200ms conversion time (this is the default).
2 = 0.125ēC resolution, 400ms conversion time.
3 = 0.0625ēC resolution, 800ms conversion time
You are setting 10 off together so that is that's at least 0.8s, probably more.
The print will have to wait for the conversion to finish, before it can print.
So If you remove the Pause, each loop will be approximately 0.8s (it actually seems to be slightly longer) you could probably try fine tuning this with a smaller Pause and move it to just after the Print "! "+s Pause 129 looks good, but at some point you will loose or gain a second every now and then in your print out.
I suspect that the first run takes longer, because it's doing some extra setting up, hence the jump to 3.
Regards, Kevin.
Edited 2022-06-21 04:37 by Bleep
Posted: 06:44pm 20 Jun 2022
  Bleep said   ... You are setting 10 off together so that is that's at least 0.8s, probably more.
The first pass through the DO loop takes as long as the uninitialized TEMPR reads take.
The subsequent passes return nearly instantaneously because the PAUSE 1000 has allowed all the TEMPR STARTs to complete. It might be possible to shave a hundred milliseconds or more off of the PAUSE 1000, but for the purpose for which this is intended, there would be no real benefit to doing so.
Other code will be calling this TEMPR & TEMPR START sequence. This was just intended to show that it could all be done in about a second as opposed to the maybe 8 seconds if each TEMPR was done individually, waiting for the result. The calling code will be able to immediately begin to process the temperature readings.
(Congrats on the "warpspeed" idea.)
Edited 2022-06-21 04:51 by lizby
Posted: 07:12pm 20 Jun 2022
Hi Peter,
Not the bug I'm looking for but nevertheless:
> new
> load "tick_bug.bas"
> list
SetTick 100, my_tick
 Print Inkey$;
Loop
End
Sub my_tick
 For j% = 1 To 1000 : Next
End Sub
> run
<Press a key or two>
[4] Print Inkey$;
Error : 1000 is invalid (valid is 1 to 10)
Am I doing something foolish ?
EDIT: OK, doesn't happen from a reset ... something else is at play, will investigate further.
Edited 2022-06-21 05:15 by thwill
Posted: 07:25pm 20 Jun 2022
OK, found what I suspect is the same issue but reproducible from a reset:
1. Reset PicoMite
2.
> load "on_key.bas"
> list
On Key on_key()
End
Sub on_key()
Print Inkey$
End Sub
> load "tick_bug.bas"
> list
 Print Inkey$;
Loop
End
Sub my_tick
End Sub
> run "on_key"
> run "tick_bug"
3. Type "a", "b", "c", "Ctrl-C"
4.
> run "on_key"
> run "tick_bug"
5. Type "a", "b", "c", "Ctrl-C"
6. Repeat steps 4 and 5 until this happens - usually happens on the first or second time:
[5] Loop
Error : LOOP without a matching DO
What a palava,
Edited 2022-06-21 05:26 by thwill
Posted: 09:38pm 20 Jun 2022
  Quote  OK, found what I suspect is the same issue but reproducible from a reset:
Anything to do with the performance tweak or unrelated? Happens in 5.07.04?
Posted: 09:47pm 20 Jun 2022
Just tested and it also happens in 5.07.04 release version from Geoff's website - looks like some corrupt piece of state so just possibly might be related to why I don't have keyboard issues the first time I run my game after a reset, but do on subsequent runs ... tenuous I know.
Edited 2022-06-21 07:48 by thwill
Tinine
Posted: 04:23am 21 Jun 2022
@Matherp and @Bleep
Many thanks and congratulations for the speed breakthrough, guys
Craig
Tinine
Posted: 04:45am 21 Jun 2022
Whoa!
I have been playing with a non-blocking debounce, based on the Cap'n's Fruit-of-the-shed principle. It needs to see a steady-state for 40ms to be valid. Within this 40ms, I increment a counter just to see how many scans occurred.
Prior to the speedup: 124-129
Now: 491-499
Posted: 07:37am 21 Jun 2022
  Quote  Just tested and it also happens in 5.07.04 release version from Geoff's website
Please try attached and if OK I'll do a proper release
PicoMiteVGA.zip
fred777
Posted: 08:07am 21 Jun 2022
Very impressive speed increase, nice!
I don't know when the change happened but the keyboard pins seem to have changed
This is the NON-vga version, after a clear_flash, no other options
PicoMite MMBasic Version 5.07.05b10
> OPTION KEYBOARD US, 0, 0, 0, 0
> SETPIN 11 , DOUT
Error : Pin 11 is reserved on startup
From the Manual:
The keyboard must be connected as follows:
Connect GP8 to PS2 socket CLOCK pin.
Connect GP9 to PS2 socket DATA pin.
I'm pretty sure I had a PS/2 keyboard working on GP8 and GP9.
And now it looks like GP11 is used.
I can't seem to find any mention of new pin assigments, are there more changes?
Posted: 08:12am 21 Jun 2022
There are no pin changes
GP8 == pin 11
Try
SETPIN GP11,dout == setpin 15,dout
fred777
Posted: 08:17am 21 Jun 2022
Aaaaargh, I constantly get pin numbers and GP numbers mixed up... sorry
Posted: 08:34am 21 Jun 2022
Thanks Peter, that seems to fix the reported issue and also, at least on preliminary testing, addresses the problem I was having with keyboard read performance after the first run.
Posted: 11:34am 21 Jun 2022
@peter,
Do we still get the 252 MHz option, or only 126 and 378?
