Forum Index : Microcontroller and PC projects : PicoMite file handling in mmbasic
| JLewis Newbie Joined: 14/06/2022 Location: United KingdomPosts: 4 |
Firstly, I just want to say hi! I'm done with lurking in the forums and just got my PicoMite VGA up and running yesterday. The last time I programmed in BASIC was around 25 years ago with AMOS on the Commodore Amiga, so needless to say, I'm a little rusty! Whilst feeling waves of nostalgia, I converted a load of cool Sinclair ZX Spectrum artwork into RGB 1-2-1 bitmaps to see how they look on the PicoMite VGA - surprisingly good, I have to say. I decided I'd program a simple slideshow to show them off... I dumped a ton of bitmaps with descriptive filenames into a folder on the SD card, thinking I'd be able to get the Pico to check the folder and automatically load each image one by one. And that's as far as I have got! Precisely nowhere lol. I thought that I would be able to scan the entire folder, then store the filenames, for example into an array, rather than explicitly name each one in the program. I don't know which command to use. Please could somebody point me in the right direction? Regards Jamie Ps. I was going to ask about how to achieve indexed colours yesterday but spotted a nice example in somebody's Mandelbrot demo |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4398 |
Hi Jamie, Welcome onboard. Sounds like you want the DIR$() function. Best wishes, Tom Edited 2022-06-16 06:14 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1772 |
Need more help? This (or something similar) should do the trick, a simple example: CONST MAXFILES=100 DIM f$(MAXFILES) ' each string takes 255 Bytes! DIM i as integer i=1 f$(i) = LCase$(Dir$("*.*", FILE)) Do While f$(i) <> "" And i<MAXFILES i=i+1 f$(i) = LCase$(Dir$()) 'PRINT f$(i) Loop ' You can add a string sort if you want Best regards Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Oops! Feel a bit silly now. I completely missed the DIR$ function Thanks for the heads up guys |
