Local Time 11:17 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Wrong characters from my keyboard under MMBasic for Windows.
Paul_L
Posted: 06:14am 13 Jun 2022
I'm trying to run the MMBasic.exe for Windows extracted from 2022-04-22_V5.07.03b10 MMBasic Windows beta.zip.
I'm using a keyboard from UNICOMP which replicates the original IBM type M keyboard.
When I type the double quote, {"} key, the tilde {~} appears.
When I type in the test line
for i=1 to 100:print i;:next
it works.
for i =1 to 100:print "Hi"
what appears on the screen is
for i=1 to 100: print ~Hi~
If I type in the test line
for i=33 to 127:print chr$(i):next
it works, and the chr$(34) {"} and the chr$(126) {~} appear where they should.
What the heck!!!!
Paul in NY
Edited 2022-06-13 16:16 by Paul_L
Paul_L
Posted: 06:24am 13 Jun 2022
The MMbasic.exe extracted from the zip download from Geoff's website works the way it should. It does not scramble the {'} and {~}.
Paul in NY
Posted: 06:29am 13 Jun 2022
Keyboard type setting in windows is wrong? Just an idea.
Paul_L
Posted: 06:33am 13 Jun 2022
Mick ... I doubt the keyboard type is set wrong. Everything else works the way it should, including when running the MMBasic.exe extracted from Geoff's website just now.
I think the problem is in the beta Windows build that I found in a thread here somewhere.
Paul in NY
Edited 2022-06-13 16:34 by Paul_L
Posted: 06:40am 13 Jun 2022
It sounds to me like one of those odd things that Unicode does. MMBasic doesn't support Unicode but MMBasic for Windows is probably using the Windows keyboard system, and hence will support Unicode (because it won't know that that is what it's doing).
MMBasic is defaulting to UK keyboard???
disco4now
Posted: 06:45am 13 Jun 2022
You need
OPTION KEYBOARD US
It defaults to UK, which from memory swaps ~ @ and " around if you actually have a US keyboard.
F4 H7FotSF4xGT
