Local Time 13:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite is fun
pwillard
Posted: 10:01am 09 Jun 2022
Ok, so I'm a noob.  But so far, my experience with the picomite (over serial until I get some additional parts) has been great.
1) I never hated basic
2) I got my first "boot to basic" computer back in 1982
2) This has been a very nostalgic experience so far.
My 80's era home computer could only wish to do what my Pico can do... so I've been giving myself challenges.
My latest challenge is to get this to work: TM1637
It's a bit tricky since it's basically a shift register (but not actually SPI) since it combines MISO and MOSI into a single bi-directional pin. It sends an ACK after 8 bits of sent data from the MCU. So, direction switching is needed.  I have the beginnings of the code done...  but the PICO seems up to the task of doing this handshake very "manually".
Anyway... off to the workbench to experiment some more.
Edited 2022-06-09 20:03 by pwillard
Posted: 10:11am 09 Jun 2022
This thread may give you some ideas
pwillard
Posted: 10:17am 09 Jun 2022
Haha...  Now, why didn't I find that?
And it's cool that my write-byte code is similar, so I'm on the right track.
That datasheet is bloody awful.
Much thanks
Follow-up:
Using the example code provided, with some quick edits and a couple of added 'pause 0.01' commands... I got it working on my Pico.  It was kind of gibberish until I added delays near the clock pulses.
You saved me a ton of experimenting and it's appreciated.
Edited 2022-06-09 23:25 by pwillard
DaveJacko
Posted: 09:27pm 04 May 2024
hi, pwillard
would you mind posting your code?
I had this display working on the micromite,
but despite putting a pause 0.01 after every clock or data change,
I'm still getting many spurious segments
Thanks if you do, and thanks if you don't
regs Dave
Try swapping 2 and 3 over
pwillard
Posted: 01:29pm 09 May 2024
I'll need to track it down...
OK, this is not something I'm using at the moment... but it worked the last time I tried it (pretty sure)
tm1637 pico time
Edited 2024-05-09 23:40 by pwillard
DaveJacko
Posted: 08:48pm 09 May 2024
thanks Pete !
palcal
Posted: 04:24am 22 May 2024
@ DaveJacko,  did you get this code to work, I'm connecting and getting the time but the display is blank.
@ pwillard    any ideas
DaveJacko
Posted: 09:01pm 22 May 2024
No joy
I have my own code that ** worked 100% on the Micromite, **
but produces largely random segments on the Pico.
I found that adding 5k pullups maybe improves things a bit.
althought there are 10k's on module
I'm going to add delays after every pin-change,
maybe try lower cpuspeed
here's the code..
' Time Bomb countdown demo 7 seg driver
' Dave J 2024
mins=1 'countdown starts at
secs=9
'dat=gp14
'clk=gp15
init
mnlp:
Pause 500
colon=colon Xor &H80
If colon Then
secs=secs-1
If secs=-1 Then
 secs=59
 mins=mins-1
EndIf
If mins=-1 Then mins=0:secs=0
EndIf
s$=Str$(secs,2,0,"0")
m$=Str$(mins,2,0,"0")
start
wrtb(&H40) 'comm1
stop
' Write COMM2 + first digit address ??
start
wrtb(&HC0) 'comm2
wrtb(dgt%(Asc(Mid$(m$,1,1))-48))
wrtb(dgt%(Asc(Mid$(m$,2,1))-48)Or colon)
wrtb(dgt%(Asc(Mid$(s$,1,1))-48))
wrtb(dgt%(Asc(Mid$(s$,2,1))-48))
stop
GoTo mnlp
'------------------- subs
Sub wrtb(b As integer) '--- write byte
tb=b
For i=0 To 7
SetPin gp15,dout 'clk lo
If (tb And 1) Then 'set bit
SetPin gp14,din
Else
SetPin gp14,dout
EndIf
SetPin gp15, din 'clk hi
tb= tb >> 1
Next i
SetPin gp15, dout 'clk lo
SetPin gp14, din 'release dat
'check ack here?
End Sub
Sub start '-------- start
SetPin gp14,dout 'dat lo
End Sub
Sub stop '--- stop
SetPin gp14, dout 'dat lo
SetPin gp15, din ' clk hi '
SetPin gp14, din ' dat hi
End Sub
Sub init '---- initialise TM1637
Pin(gp14)=0
Pin(gp15)=0
SetPin gp14,din,pullup
SetPin gp15,din,pullup
Dim dgt%(9)=(&H3F,&H06,&H5B,&H4F,&H66,&H6D,&H7D,&H07,&H7F,&H6F)
' ,&H77,&H7C,&H39,&H5E,&H79,&H71) 'A..F
' degree symbol is &H63, C is &H39
' colon - or 2nd digit with &H80
start 'reset, enable, brightness
wrtb(&H80+8+7) '0=dim
stop
End Sub
