Local Time 04:16 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA: some Entertainer-ment and some bugs (?)
     Page 1 of 3
Posted: 12:41pm 08 Jun 2022
Hi folks,
Here's something musical that I'm working on.
It should work on MMB4W, CMM2 and PicoMite(VGA).
I am however having 2 issues specifically on the PicoMite:
   1. The usual OPTION BREAK 4 : ON KEY 3 trick doesn't seem to work to allow me to intercept the break key - so I can call PLAY STOP.
   2. If I try to play on more than 2 channels on the PicoMite then I get white noise playing on the additional channels - possibly this is a H/W issue; I'm using @Mixtel90's PicoGAME - prototype PCB.
Option Base 0
Option Default None
Option Explicit On
' On Key 3 doesn't seem to work on PicoMite.
' Option Break 4
' On Key 3, on_break
If InStr(MM.Device$, "PicoMite") Then Save "entertainer.bas"
Dim channel1%(256), channel2%(256), channel3%(256), channel4%(256)
Dim err$
Dim s$
 Line Input "How many channels (1-4)? ", s$
 Print
 Select Case Val(s$)
   Case 1 To 4 : Exit Do
 End Select
Loop
Dim num_channels% = Val(s$)
music.parse(channel1%(), "qD4,qD#4")
music.parse(channel1%(), "qE4,1C5,qE4,1C5,qE4,qC5")
music.parse(channel1%(), "2C5,q-,qC5,qD5,qD#5")
music.parse(channel1%(), "qE5,qC5,qD5,qE5,qE5,qB5,1D5")
music.parse(channel1%(), "3C5,qD4,qD#4")
music.parse(channel1%(), "3C5,qA5,qG4")
music.parse(channel1%(), "qF#4,qA5,qC5,qE5,qE5,qD5,qC5,qA5")
music.parse(channel1%(), "3D5,qD4,qD#4")
music.parse(channel1%(), "2C5,qC5,q-,qC5,qD5")
music.parse(channel1%(), "qE5,qC5,qD5,qE5,qE5,qC5,qD5,qC5")
music.parse(channel1%(), "2C5,qC5,qE4,qF4,qF#4")
music.parse(channel1%(), "1G4,qA5,qG4,qG4,qE4,qF4,qF#4")
music.parse(channel1%(), "1G4,qA5,qG4,qG4,qE5,qC5,qG4")
music.parse(channel1%(), "qA5,qB5,qC5,qD5,qE5,qD5,qC5,qD5")
music.parse(channel1%(), "2G4,qG4,qE4,qF4,qF#4")
music.parse(channel1%(), "1G4,qA5,qG4,qG4,qG4,qA5,qA#5")
music.parse(channel1%(), "1B5,q-,1B5,qA5,qF#4,qD4")
'music.parse(channel1%(), "qB5,q-,qB5,q-,qB5,qA5,qF#4,qD4")
music.parse(channel1%(), "2C5,qC5,qG4,qF#4,qG4")
music.parse(channel1%(), "1C5,qA5,qC5,qC5,qA5,qC5,qA5")
music.parse(channel1%(), "qG4,qC5,qE5,qG5,qG5,qE5,qC5,qG4")
music.parse(channel1%(), "1A5,1C5,qE5,1D5,qD5")
music.parse(channel1%(), "3C5")
' Placeholder code until I've transcribed the notes for the other channels.
' Play the same music on each channel offset by 1 beat.
LongString Append channel2%(), Chr$(0) + Chr$(0)
LongString Append channel3%(), Chr$(0) + Chr$(0) + Chr$(0) + Chr$(0)
LongString Append channel4%(), Chr$(0) + Chr$(0) + Chr$(0) + Chr$(0) + Chr$(0) + Chr$(0)
Dim i%
For i% = 0 To LLen(channel1%()) - 1
 LongString Append channel2%(), Chr$(LGetByte(channel1%(), i%))
 LongString Append channel3%(), Chr$(LGetByte(channel1%(), i%))
 LongString Append channel4%(), Chr$(LGetByte(channel1%(), i%))
Next
' Terminate each channel with 255
LongString Append channel1%(), Chr$(&hFF)
LongString Append channel2%(), Chr$(&hFF)
LongString Append channel3%(), Chr$(&hFF)
LongString Append channel4%(), Chr$(&hFF)
' Pad each channel with 255 until reach 64-bit boundary and they are all the same length.
Dim count% = Max(LLen(channel1%()), LLen(channel2%()))
count% = Max(count%, LLen(channel3%()))
count% = Max(count%, LLen(channel4%()))
Do While count% Mod 8 > 0 : Inc count% : Loop
Do While LLen(channel1%()) < count% : LongString Append channel1%(), Chr$(&hFF) : Loop
Do While LLen(channel2%()) < count% : LongString Append channel2%(), Chr$(&hFF) : Loop
Do While LLen(channel3%()) < count% : LongString Append channel3%(), Chr$(&hFF) : Loop
Do While LLen(channel4%()) < count% : LongString Append channel4%(), Chr$(&hFF) : Loop
' Combine the channels into a single music buffer.
Dim music%(1 + (count% / 2))
For i% = 0 To count% - 1
 LongString Append music%(), Chr$(LGetByte(channel1%(), i%))
 LongString Append music%(), Chr$(LGetByte(channel2%(), i%))
 LongString Append music%(), Chr$(LGetByte(channel3%(), i%))
 LongString Append music%(), Chr$(LGetByte(channel4%(), i%))
Next
' music.print_data(music%())
' Play music buffer via interrupt.
Dim music_ptr% = Peek(VarAddr music%()) + 8
SetTick 200, music.play_interrupt, 1
Do : Loop
End
Sub music.parse(buf%(), s$)
 Local s_idx% = 1
 Local ch$ = ","
 Do While ch$ = ","
   If music.parse_note%(s$, s_idx%, buf%()) <> 0 Then
     Error err$ + " : s_idx = " + Str$(s_idx%)
   EndIf
   Inc s_idx%
   ch$ = Mid$(s$, s_idx%, 1)
   Inc s_idx%
 Loop
End Sub
Sub on_break
 Play Stop
 Option Break 3
 End
End Sub
Function music.parse_note%(s$, s_idx%, buf%())
 music.parse_note% = -1
 Local ch$ = Mid$(s$, s_idx%, 1)
 ' Parse duration.
 Local duration!
 Select Case ch$
   Case "q": duration! = 0.5
   Case "1", "2", "3", "4": duration! = Val(ch$)
   Case Else
     err$ = "Syntax error: expected duration"
     Exit Function
 End Select
 Inc s_idx%
 ' Parse note.
 Local n% = 0 ' 0 = Rest, 1 = A0
 Select Case ch$
   Case "A" : n% = 1
   Case "B" : n% = 3
   Case "C" : n% = 4
   Case "D" : n% = 6
   Case "E" : n% = 8
   Case "F" : n% = 9
   Case "G" : n% = 11
   Case "-" : ' Do nothing
   Case Else
     err$ = "Syntax error: expected note"
     Exit Function
 End Select
 If n% = 0 Then
   LongString Append buf%(), Chr$(0)
   music.parse_note% = 0
   Exit Function
 EndIf
 Inc s_idx%
 ' Parse b or #.
 Local off% = 0
 Select Case ch$
   Case "b" : off% = -1
   Case "#" : off% = 1
 End Select
 If off% <> 0 Then
   Inc n%, off%
   Inc s_idx%
 EndIf
 ' Parse octave.
 If Not Instr("012345678", ch$) Then
   err$ = "Syntax error: expected octave"
   Exit Function
 EndIf
 Inc n%, 12 * Val(ch$)
 ' Write music data into buffer.
 Local i%
 For i% = 1 To 2 * duration!
   LongString Append buf%(), Chr$(n%)
 Next
End Function
Sub music.print_data(buf%())
 Local count% = 0, i%, p% = Peek(VarAddr buf%()) + 8
 Open "entertainer.inc" For Output As #1
 Print #1, "Data " Str$(LLen(buf%())) " ' Number of bytes of music data."
 For i% = 0 To LLen(buf%()) - 1 Step 8
   Print #1, Choice(count% = 0, "Data ", ", ");
   Print #1, "&h" Hex$(Peek(Integer p%), 16);
   Inc p%, 8
   Inc count%
   If count% = 4 Then Print #1 : count% = 0
 Next
 Close #1
End Sub
Sub music.play_interrupt()
 ' Play channel 1.
 Local n% = Peek(Byte music_ptr%)
 Select Case n%
   Case 0 : Play Sound 1, B, O
   Case 1 To 254 : Play Sound 1, B, S, 440 * 2^((n% - 49) / 12.0)
   Case 255 : Play Stop : End
 End Select
 Inc music_ptr%
 ' Play channel 2.
 If num_channels% > 1 Then
   Select Case n%
       Case 0 : Play Sound 2, B, O
       Case 1 To 254 : Play Sound 2, B, S, 440 * 2^((n% - 49) / 12.0)
   End Select
 EndIf
 Inc music_ptr%
 ' Play channel 3.
 If num_channels% > 2 Then
   Select Case n%
       Case 0 : Play Sound 3, B, O
       Case 1 To 254 : Play Sound 3, B, S, 440 * 2^((n% - 49) / 12.0)
   End Select
 EndIf
 Inc music_ptr%
 ' Play channel 4.
 If num_channels% > 3 Then
   Select Case n%
       Case 0 : Play Sound 4, B, O
       Case 1 To 254 : Play Sound 4, B, S, 440 * 2^((n% - 49) / 12.0)
   End Select
 EndIf
 Inc music_ptr%
End Sub
Posted: 12:48pm 08 Jun 2022
Option break 4
On key 3,myint
Loop
Sub myint
Option break 3
End
End Sub
works as expected
2
Can't test until next week - no relevant H/W
Posted: 01:22pm 08 Jun 2022
Something very fishy is going on:
This is my program "break_bug.bas":
Save "break_bug.bas"
Option Break 4
On Key 3,myint
Loop
Sub myint
Option Break 3
End
End Sub
Now, I do the following:
> NEW
> LOAD "break_bug.bas"
> RUN
Ctrl-C doesn't work, need to use Ctrl-D
> RUN
> EDIT
F2:Run
> EDIT
Comment the first line, i.e.
' Save "break_bug.bas"
F2:Run
Ctrl-C "works" but the following error is reported:
[6] Loop
Error : Unknown command
> RUN
[6] Loop
WTF ???
Edited 2022-06-08 23:23 by thwill
Posted: 01:31pm 08 Jun 2022
saving a program in a program is pretty bizarre and should probably give an error but even with that in the program I can't replicate
Posted: 01:36pm 08 Jun 2022
  matherp said  saving a program in a program is pretty bizarre and should probably give an error ...
Please don't, it's exceptionally useful on the 'mites otherwise I'm always losing work due to the EDITor not saving to the SD card.
  Quote  ... but even with that in the program I can't replicate
Very strange. Just to eliminate the obvious are you using the PicoMite or PicoMiteVGA firmware - I'm on the latter.
Posted: 01:39pm 08 Jun 2022
latter - b6 just posted
Posted: 01:40pm 08 Jun 2022
The hardware won't make a difference. It's just the usual PWM audio on pins GP6 and GP7. After that there are just some links that replace the filter with a resistor for headphones.
Posted: 01:55pm 08 Jun 2022
Most perplexing, I have also updated to b6 and am now running this program:
On Key 97,my_int
Print "Hello"
Do : Loop
End
Sub my_int
Print "World"
End Sub
Pressing 'a' on the keyboard is not causing it to say "World".
However this program will print "World" when you press 'a':
On Key my_int
Print "Hello"
Do : Loop
End
Sub my_int
If Asc(Inkey$) = 97 Then Print "World"
End Sub
I repeat my earlier WTF ???
Posted: 01:57pm 08 Jun 2022
What are you using as a terminal?
Posted: 02:03pm 08 Jun 2022
  matherp said  What are you using as a terminal?
A VGA monitor (actually VGA video capture) and a PS/2 keyboard.
EDIT: ... and it works fine with Tera Term connected by USB. So looks like it is possibly something to do with the PS/2 support - this is a real (but modern) PS/2 keyboard that I've frequently used with my CMM1.
Edited 2022-06-09 00:10 by thwill
Posted: 02:10pm 08 Jun 2022
  Quote  and a PS/2 keyboard.
Now had you said that at the beginning.......
PicoMiteVGA.zip
Michal
Posted: 02:18pm 08 Jun 2022
Hi matherp.
Could you upload the current version of your MMBASICW (because I'm already lost in the versions)?
Michal
Posted: 02:51pm 08 Jun 2022
Everyone's a critic. Thanks Peter, that works.
@Mixtel90 (or anyone else with a PicoMiteVGA board and audio output at hand) is there any chance you could run the program in the OP with 3/4 channels and confirm you are hearing white noise too ?
  Michal said  Could you upload the current version of your MMBASICW (because I'm already lost in the versions)?
Assuming you mean MMB4W then wrong thread, work backwards through this one looking for a download:
   https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=14614&LastEntry=Y#187081.
Edited 2022-06-09 00:52 by thwill
Posted: 03:29pm 08 Jun 2022
  Quote   is there any chance you could run the program in the OP with 3/4 channels and confirm you are hearing white noise too ?
Suggest you start with a simple test at the command line and see if you can set up 4 tones and hear them (or better see on the scope)
Posted: 03:39pm 08 Jun 2022
My scope is a toy operated by an ignoramus.
This generates white noise for me at the command-line:
Play Sound 1,B,S,500:Play Sound 2,B,S,560:Play Sound 3,B,S,600
Edited 2022-06-09 01:40 by thwill
Posted: 03:40pm 08 Jun 2022
Just white noise? or two tones with white noise as the third?
Posted: 03:43pm 08 Jun 2022
  matherp said  Just white noise? or two tones with white noise as the third?
I *think* noise as the third - like you say, need a scope to be certain.
Posted: 03:52pm 08 Jun 2022
Have you tried with lower volumes? e.g. set volume for each channel to say 5
Posted: 04:11pm 08 Jun 2022
Just check something, Tom. The prototype board was messed up on the phone jack IIRC. Is yours working correctly? If in doubt take the links out of LB2 and check for the tones on the top two pins or the bottom two pins. Then compare with what you hear on the output jack when you put the links back.
  matherp said  Have you tried with lower volumes? e.g. set volume for each channel to say 5
I have now and that eliminates 95% of the issue, just a couple of clicks and pops remain.
For my education can you explain ?
     Page 1 of 3
