Local Time 11:31 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Fast and Durty PicoMiteVGA Demo
Martin H.
Posted: 02:34pm 06 Jun 2022
A little Demo I coded 35 years ago in 6809Assembler on the Dragon32.
Just 4 fun to test the BLIT - Function in MMBasic VGA
Save both Pictures as Ball1.bmp and Ball2.bmp in the same Folder as the .Bas file
'Bouncing Ball Demo by Martin Herhaus 2022
'litle BLIT Demo for MM Basic Pico-VGA
MODE 2
Colour RGB(black),RGB(white)
BL=1:H=86:W=84
CLS
x=0:y=0
Load image "Ball1.bmp"
For f=1 To 4
 Blit read #f,x,y,w,h
 x=x+w:If f=2 Then x=0:y=y+h
Next f
Load image "Ball2.bmp"
x=0:y=0
For f=5 To 8
 x=x+w:If f=6 Then x=0:y=y+h
Next f
an=1:SN=1:rot=-1
BX=0: BY=0: BDir=1
CLS
 by=Int(Sin(sn*Pi/128)*160):SN=SN+1
 SN=SN And 255
 If by<0 Then BY=-BY
 BY=160-by
 Blit write #an,bx,by,W,H
 an=an+rot:If an=9 Then an=1
 If AN=0 Then an=8
 bx=bx+bdir:If BX>=232 Or BX<1 Then bdir=-bdir:rot=-rot
 Pause 20
Loop
Sub free
For f=1 To 8:Blit close #f:Next f
End Sub
as it uses a lot of memory, I added the "free" function to get the memory back after the Program has ended.
Save this as Ball1.bmp:
or just use the Zip File: ball.zip
if it runs to slow, you can decrease the Pause Value at the end of the Loop
have fun.
Edited 2022-06-07 04:05 by Martin H.
'no comment
Posted: 07:15pm 07 Jun 2022
Hi Martin,
I get a syntax error at this line.
Sprite write #an,bx,by,W,H
Running the latest MMBasic 5.07.05b1
When I replace the line with
Sprite show #an,bx,by,1
The ball bounces, but leaves painting artefacts behind. I didn't change anything else in your program. Maybe I have to use a framebuffer ?
Edited 2022-06-08 05:26 by Volhout
Bleep
Posted: 08:17pm 07 Jun 2022
Yes I did get this going myself, from memory, all it needed was
Sprite write #an,bx,by,1
So replace the W,H with 1, I'll check & confirm when I'm able.
Regards Kevin
Martin H.
Posted: 03:36am 08 Jun 2022
  Volhout said  Hi Martin,
ähm ?! ... as I wrote this Demo on the latest final Version of PicoMiteVGA V5.07.04, there is no Sprite command in it.
Edited 2022-06-08 14:07 by Martin H.
'no comment
Posted: 05:32am 08 Jun 2022
Blit and Sprite are now the same as I read in the 5.07.05 notes.
In fact if you run your program in 5.07.05 it translates the word BLIT in SPRITE.
With the effect that you get the error.
Even if I type the line new in the editor, it translates BLIT in SPRITE.
I am not sure if that is correct. With the BLIT you could move arbitrary blocks of video memory (i.e. determine width and height yourself). Sprite does not support that.
Anyway. I will need to revert back to 5.07.04 to test your program as it originally was....
P.S. I do not see a way to leave the DO LOOP that moves the balls (no EXIT, no call to that sub). That means that the sub that frees up memory is never called. Correct ?
Edited 2022-06-08 16:08 by Volhout
Martin H.
Posted: 10:26am 08 Jun 2022
  Volhout said  Blit and Sprite are now the same as I read in the 5.07.05 notes.
sorry, I had no Time to test the new Functions from the Beta b4/B5 jet. So this little demo was made with the functions in mmbasic 5.07.04. (which i allready havent tested all) .. it was fast and durty, which means dirty^2
And yes, ther is no call for the "free" sub, so after the PAUSE command, one can add the "anykey" to call "free" and exit the loop
if inkey$<>"" then free:mode 1:exit Do
Edited 2022-06-08 20:31 by Martin H.
'no comment
Martin H.
Posted: 05:13pm 24 Jun 2022
ok, for Testing, i now have installed the Beta (5.07.05b5)
looks like the Sprite Routine has no opaque Mode,
which was default in the Blit
So from this, the Image looses all its Black parts and so it does not overwrite the older Image on the Screen. Also the original Black parts are White / Transperent. This little fix does overwrite the old image before it draws the new sprite...
(Flickers like hell)
'version for Sprite / Beta
MODE 2
BL=1:H=85:W=85
CLS
x=0:y=0
For f=1 To 4
 Sprite read #f,x,y,w,h
Next f
x=0:y=0
For f=5 To 8
Next f
an=1:SN=1:rot=-1
BX=0: BY=0: BDir=1:bx1=0:by1=0
CLS
 SN=SN And 255
 If by<0 Then BY=-BY
 BY=160-by
 Box bx,by,h+1,w+1,,RGB(white),RGB(white)
 Sprite show #an,bx,by,2:bx1=by:by1=by
 If AN=0 Then an=8
 Pause 20
Loop
Edited 2022-06-25 03:14 by Martin H.
'no comment
