Local Time 03:41 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New PicoMiteVGA design
     Page 1 of 3
al18
Posted: 08:40pm 04 Jun 2022
Yesterday a new PicoMiteVGA design popped up on my YouTube feed. This design includes a MCP23017 for 16 pin I/O at http://land-boards.com/blwiki/index.php?title=PiPicoMite01#Assembly_Sheet
The bare board is on sale on Www.Tindie.com
panky
Posted: 03:27am 05 Jun 2022
Very interesting and detailed information. The MMBasic v uPython is perhaps a little midleading - the Basic code example (with respect) is pretty clunky - if you use a for/next loop, the speed at the default 133MHz comes down to a bit over 1 second, less than twice that of uPython.
Nice catch,
Doug.
Posted: 06:28am 05 Jun 2022
That's a very nice design, although I always feel that the SDcard should be easily accessible. It's a pointless feeling really, as how often do we want to remove or insert an SD card while the board is running? It's great to see the design so well documented too - I highly approve.
I'm not one to judge the merits or otherwise of the software, being such a terrible programmer myself. :)
The price of $12 + postage for a bare board feels a little steep to me, but I've no idea what's involved in selling on Tindie - there are probably charges.
Posted: 07:53am 05 Jun 2022
No mention at all of Geoff or Peter, who came up with and designed the original.
The page almost makes it sound like they came up with the entire concept and the code.
Perhaps I missed something, perhaps they did mention it, but I did not see it.
I just like to give credit where credit is due, and I hate it when people DON'T.
Posted: 08:09am 05 Jun 2022
True - I didn't see anything either. I didn't follow any of the links on the page so there may be something there, but it would have been nice to give credit on the main page.
EDIT - I've added credits now. :)
Geoff has already had problems with others monetizing his designs and it's not fair.
Edited 2022-06-05 18:22 by Mixtel90
Tinine
Posted: 10:44am 05 Jun 2022
  panky said  Very interesting and detailed information. The MMBasic v uPython is perhaps a little midleading - the Basic code example (with respect) is pretty clunky - if you use a for/next loop, the speed at the default 133MHz comes down to a bit over 1 second, less than twice that of uPython.
Nice catch,
Doug.
Where is this comparison? I don't see it
Craig
Posted: 11:04am 05 Jun 2022
It's a video.
Closer to the Python code:
a=timer
do while i<100000
inc i
loop
? timer-a
runs in 3732ms on a standard PicoMite VGA. It's not a very fair test.
a=timer
label:
inc i
if i<100000 then goto label
? timer-a
runs in 7149ms
That i=i+1 is a bummer. :)
Edited 2022-06-05 21:41 by Mixtel90
Tinine
Posted: 12:09pm 05 Jun 2022
You beat me to it
Just reading the uPython docs. Pretty cool how it can use the 2nd processor to run a thread
Craig
Bleep
Posted: 12:28pm 05 Jun 2022
you can also use integers for x, which gains a bit, also run at 252Mhz, which gains a lot. :-)
Dim Integer x
Dim Float a
a=Timer
Do While x<100000
Inc x
Loop
Print Timer-a
Which gives 1668.3 mS
The obvious thing to do is use a For loop.
Dim Integer x,y
Dim Float a
a=Timer
For x=0 To 100000
Inc y
Next
Print Timer-a
Which gives 748.9 mS presumably because For loops are well optimised for the purpose.
As you say though a very silly speed test.
Edited 2022-06-05 22:43 by Bleep
Tinine
Posted: 01:44pm 05 Jun 2022
I fail to see the "silly" bit. Two scripted languages. I didn't expect such a huge difference, TBH.
Craig
Bleep
Posted: 01:50pm 05 Jun 2022
Silly, because it is only testing a minuscule part of both languages!
Tinine
Posted: 02:18pm 05 Jun 2022
  Bleep said  Silly, because it is only testing a minuscule part of both languages!
Before I ever make those kind of statements, I usually have an example to back it up.
Craig
Posted: 02:19pm 05 Jun 2022
I'd have been happier if he'd used as close as possible to the same construct in both languages. He's got MMBasic having to do a compare and a mathematical increment inside the loop and a conditional jump to a label to close it, whereas he has Python using a While loop and an inc (no compare and the loop is automatic). On the PicoMite it gives a difference of 3.7s against 10s. It would be difficult to write the MMBasic less efficiently or the Python more efficiently.
Posted: 02:47pm 05 Jun 2022
FYI the GOTO command is not locked in RAM so has to go to flash to read the firmware.
The fastest construct in Basic is the for LOOP as the 100000 is only read once whereas on a do while it is read each time through the loop
The fastest do loop I can find is
x%=100000
do
inc x%,-1
loop while x%
Tinine
Posted: 02:55pm 05 Jun 2022
It's irritating that these people are ignorant of the fact that BASIC has moved on. I wouldn't have used the goto/label cr@p back in the 80s, even. QuickBasic did away with the need for this.
Craig
Michal
Posted: 12:53pm 06 Jun 2022
It's worth trying something less trivial:
PRINT "START"
T=TIMER
A=1.0
B=0.0
L=0
FOR I=0 TO 99
 FOR J=0 TO 999
   A=A+0.000001
   B=B+SIN(A!)
   inc L
 NEXT J
NEXT I
PRINT "A ";A
PRINT "B ";B
PRINT "L ";L
PRINT"Time MMBASIC=";TIMER-T;" msec"
START
A  1.1
B  86706.20931
L  100000
Time MMBASIC= 10579.187 msec
and:
import math,time
print("START")
i: int
j: int
l: int
t=time.ticks_ms()
a = 1.0
b = 0.0
l = 0
for i in range(0, 100):
   for j in range(0, 1000):
       a=a+0.000001
       b=b+math.sin(a)
       l=l+1
print("a ",a);
print("b ",b);
print("l ",l);
print("Time MicroPython",time.ticks_ms()-t," msec");
START
a  1.095367
b  86606.32
l  100000
Time MicroPython 4449  msec
And see the results
Michal
Michal
duplicate
Edited 2022-06-06 22:53 by Michal
Posted: 01:09pm 06 Jun 2022
It's what I love about benchmarks. You can design a compiler or interpreter to run benchmarks really well - and sacrifice real world performance in the process. How often would anyone actually run anything like any of these examples in the real world? You very often find that actual differences are virtually meaningless - especially if you have to wait for interaction with a user.
Posted: 01:11pm 06 Jun 2022
Note that python appears to only be using single precision FP and the answer is therefore wrong/less accurate. (0.000001 * 100000 =
This is slightly faster by the way
Print "START"
Dim integer i,j,l
T=Timer
A=1.0
B=0.0
L=0
For I=0 To 99
For J=0 To 999
  Inc a,0.000001
  Inc b,Sin(A)
  Inc L
Next
Next
Print "A ";A
Print "B ";B
Print "L ";L
Print "Time MMBASIC=";Timer-T;" msec"
Edited 2022-06-06 23:12 by matherp
Posted: 01:12pm 06 Jun 2022
Amazing that uPython does not give a correct result for A.
100x1000x0.000001 = 0.1, so A should be exactly 1.1. Not 1.095. I would not design a bridge using uPyton... autch...
Unless I am mistaken of coarse...?
VGApicomite running at 252MHz  solves this in 4.947 seconds.
VGApicomite running at 126MHz  solves this in 10.028 seconds.
I have used integers for l,i and j (just as uPython) l%,i%,j%
     Page 1 of 3
