Local Time 04:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite...I've done a big boo boo
Namaman3000
Posted: 07:23am 21 May 2022
Hi all,
Firstly I'm very new to the world of microcontrollers...and it's only taken me two days to destroy two Picos...I'm here seeking help from super smart people like yourself.
So a friend lent me his Pi Pico and recommend I use PicoMite as I do know a little about programming in BASIC. I also happened to have a 2x16 LCD display and a PCF8574 8 bit I2C Port Expander from another project, and after some searching I found this code for the Micromite:
https://www.thebackshed.com/forum/ViewTopic.php?TID=6715
With the simple addition of 'SetPin gp0, gp1, i2c', I had the program up and running on my 2x16 LCD display. I even wrote a small program to move a character around the screen by pushing direction keys. Yay!!!
My friend then lent me his pico Backpack and his LCD color screen attachment. Unfortunately it didn't work and the screen backlight was fully lit and I could not make anything appear on his LCD screen.
I tried typing in. the following to initialise it:
OPTION reset
OPTION LCDPANEL ILI9341, LANDSCAPE,GP14,GP13,GP12,gp20
OPTION TOUCH GP15,GP17
Backlight 40
Text 10,10,"hello world"
...but every time I typed the 'OPTION' command the USB serial link to the pico would crash, and I would need to log back in.
Thinking this was a faulty pico my friend lent me his other pico and as soon as I plugged it in to the Backpack the new pico and color LCD worked perfectly.
I played with it for a little bit then plugged my I2C 2x16 LCD display and a PCF8574 setup back in and ran my little 'control a character' program.
After that I then tried to run the code for the large LCD color screen and I noticed that the backlight was full on and AGAIN I could not enter any 'OPTION' command without the pico dropping the USP serial connection.
So now I seem to have partially bricked two of my friends picos...feeling real bad.
I have tried using the flash_nuke.uf2 program to reset everything, but that doesn't change my situation. I have also tried doing a CLOSE i2C, which also didn't change anything...So I'm really stuck.
Any help or advice would be greatly appreciated. Would love to figure out how to get these two pics up and running again.
Cheers!
Posted: 07:35am 21 May 2022
Fear not, the PicoMite always restarts and thus drops the serial connection when you use most/all permanent OPTION commands (they still take effect when the Pico restarts), it is a bl**dy nuisance but it's just how it works.
I believe some terminal programs cope better than others with the link dropping. What are you using TeraTerm? PuTTY?
Edited 2022-05-21 17:38 by thwill
Posted: 07:38am 21 May 2022
Welcome, fellow kiwi.
This is very interesting.
There is no reason I can think of, for this to be happening, OTHER then the fact that the PCF8574 modules.
Are you running the 8574 modules from 5v?
Probably.
If that is the case, the output from the module - being 5v - might be killing your PicoMite modules, as they CANNOT tolerate anything higher then 3.6v absolute maximum.
On ANY I/O pin.
So, IF....you are using the 8574 module connected to 5v, with it's I/O(SCL and SDA) connected to the PicoMite WITHOUT a level-shifting module between the 8574 and the PicoMite, you might be killing the PicoMite that way.
basically, anything that is happy at 3v3 can be directly interfaced, but a series resistor is recommended.  If you try to connect ANYTHING that has a 5v logic level, and you DON'T use a level-shifter, you can kill the PicoMite module, as it simply does not have any 5v tolerant I/O pins.
When you type in an OPTION command that sets up something permanent the firmware restarts. This causes the USB link to drop and then re-establish. If you use a terminal program like teraterm this will happen automatically. What you are seeing is not a problem just the way things work.
Can't help with the backpack unless you tell us which version
Namaman3000
Posted: 07:40am 21 May 2022
Hi Tom,
Thanks for the reply.
I've used PuTTY, Teraterm, Terminal in OS X, and presently using MacWise on OS X.
I didn't have any issues using the OPTION command dropping the link before running that Micromite code for the 2x16 LCD.
Posted: 07:41am 21 May 2022
See my answer first, I think Grogster has looked for a hardware answer to a software problem ;-) ... or maybe not.
Edited 2022-05-21 17:47 by thwill
Namaman3000
Posted: 07:45am 21 May 2022
  Grogster said  Welcome, fellow kiwi.
Errrr...bummer.
I had the 8574 module powered from the V-SYS pin.
Namaman3000
Posted: 07:50am 21 May 2022
  matherp said  Can't help with the backpack unless you tell us which version
It's a revC from 'Silicon Chip"
http://www.siliconchip.com.au/Shop/8/4025
Posted: 07:53am 21 May 2022
  Quote  It's a revC from 'Silicon Chip"
In which case, there are no open source docs or details so only those with a magazine can help.
With the Pico go back to basics. Test the pins with an LED (SETPIN  n,dout:PIN(n)=1 etc.). Then if OK test them as inputs by linking a  known good output to each other pin in turn and see if you can read OK
Edited 2022-05-21 17:55 by matherp
Namaman3000
Posted: 08:45am 21 May 2022
  Quote  Test the pins with an LED (SETPIN  n,dout:PIN(n)=1 etc.). Then if OK test them as inputs by linking a  known good output to each other pin in turn and see if you can read OK
I'll give that a go. Thanks
Edited 2022-05-21 18:45 by Namaman3000
Namaman3000
Posted: 08:49am 21 May 2022
It does seem odd that both GP0 and GP1 (the pins connected to the 8574) seem to still function fine, but potentially other I/O pins not directly connected to the 8574 are dead...maybe this is just the way it goes???
Posted: 09:22am 21 May 2022
Don't assume it's a hardware fault; I'm completely cack-handed and I've yet to kill one. Much more likely is software or user error. Provide a detailed description of what you are doing and seeing from first powering on the PicoMite and I'm sure someone here will have a "Eureka" moment.
Edited 2022-05-21 19:24 by thwill
Namaman3000
Posted: 10:03am 22 May 2022
  thwill said  Don't assume it's a hardware fault; I'm completely cack-handed and I've yet to kill one. Much more likely is software or user error.
I just found this vid of a guy hooking up his screen exactly the same way I did:
https://www.youtube.com/watch?v=LFpukhptDac
there are also some comments talking about 5V vs 3.3V potential issues
Phil
Edited 2022-05-22 20:10 by Namaman3000
Posted: 10:45am 22 May 2022
You have set the option for system spi. And you have an option for the lcd panel set for differen pins.
Normally system spi is the set of pins that you use to connect lcd and sd card to.
