Local Time 04:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite SD card
Kalevi
Posted: 10:22am 09 May 2022
Firmware loaded OK. MMBasic running OK. GUI calbrate OK. Picomite demo OK. Typing in  word 'files' brings up message: 'SD card not found'. I have checked for hardware problems (connections, shorts, wrong earths) none found. The card checks OK in another machine.
Mauri
Posted: 10:29am 09 May 2022
What does OPTION LIST say ?
Posted: 03:35am 10 May 2022
As thwill has hinted at, you have to tell MMBASIC that there is an SD card connected.
By default, MMBASIC will assume that it does NOT have an SD card.
From the PicoMite manual, page 38: "SD Card Support"
SD cards use the SPI protocol for communications and this needs to be specifically configured before they can be used. First the “system” SPI port needs to be configured. This is a port that will be used for system use (SD Card, LCD display and the touch controller on a LCD panel).
There are a number of ports and pins that can be used (see the section PicoMite Hardware) but this example uses SPI on pins GP18, GP19 and GP16 for Clock, MOSI and MISO.
OPTION SYSTEM SPI GP18, GP19, GP16
Then MMBasic must be told that there is an SD card attached and what pin is used for the Chip Select signal:
OPTION SDCARD GP22
These commands must be entered at the command prompt (not in a program) and will cause the PicoMite to restart. This has the side effect of disconnecting the USB console interface which will need to be reconnected.
When the PicoMite is restarted MMBasic will automatically initialise the SD card interface. This SPI port will then not be available to BASIC programs (i.e. it is reserved). To verify the configuration you can use the command OPTION LIST to list all options that have been set including the configuration of the SD Card.
Where no other devices share the SPI bus the SD Card can be set up with:
OPTION SDCARD CSpin, CLKpin, MOSIpin, MISOpin
In this case the pins can be assigned completely flexibly and do not need to be capable of SPI operation.
Kalevi
Posted: 10:12am 10 May 2022
The OPTIONs are as suggested by Admin Group except for SDCard:
OPTION SDCARD GP21. In Silicon Chip design GP21 the pin used for SD Card.
PG22 is used for Infrared input.
Posted: 10:21am 10 May 2022
If, as implied,  you are using the SC design then most of us have no access to the design which make it difficult to help. Normally, if the connections and options are correct, issues with SD are solved with improved power supply and/or decoupling the SD supply from the main supply as in my designs.
