Local Time 04:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Error in line 11: A sub/fun has the same name: FUNC_B
LeoNicolas
Posted: 05:25pm 08 May 2022
What am I doing wrong?
MMBasic for Windows, version 5.07.03b9
func_a(0)
function func_a(t)
   ? "func_a(" + str$(t) + ")"
   func_b(10)
   if t=0 then func_a=func_a(1)
end function
function func_b(v)
   ? "func_b()"
   func_b=v ' <===== Line 11
end function
Posted: 05:42pm 08 May 2022
Isn't it seeing func_b as a variable in that line? It's already used the name func_b() as a function. Can you do that?
LeoNicolas
Posted: 05:57pm 08 May 2022
Hum, option explicit has fixed the issue
Posted: 06:00pm 08 May 2022
You have a function called recursively which MMbasic can't do. The MM2 fails on this as well albeit with a different error
