Local Time 05:08 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C / I2C2 ... how to address PicoMite slave devices.??
kermess
Posted: 01:23pm 28 Apr 2022
Hi.
I am interested in knowing how to assign addresses to various PicoMites so that I can converse with them.
Master will be a PicoMite and slaves will also be PicoMites.
Thank you very much.
David.
From Barcelona.
Posted: 01:56pm 28 Apr 2022
From the Picomite manual: I2C SLAVE    See Appendix B
Posted: 02:30pm 28 Apr 2022
Also see the "Getting Started With the Micromite" book on Geoff's site. Page 70 onward gives an in depth example. If it's a purely local connection between the PicoMites you can use any addresses, but if other things are on the I2C bus you must avoid those addresses.
Tinine
Posted: 04:46pm 28 Apr 2022
Because it is possible, doesn't mean that it's the best solution.
I prefer...
Craig
Posted: 05:11pm 28 Apr 2022
... and I'd prefer several PicoMites in a 10MHz serial SPI ring (doesn't need CS pins or addresses), but that wouldn't answer the original question either. ;)
Tinine
Posted: 07:38pm 28 Apr 2022
  Mixtel90 said  ... and I'd prefer several PicoMites in a 10MHz serial SPI ring (doesn't need CS pins or addresses), but that wouldn't answer the original question either. ;)
Data not buffered....processor would be tied up servicing the SPI.
Craig
Posted: 10:18am 30 Apr 2022
That's only because MMBasic doesn't support SPI slave mode. It's always a master. A slave won't produce the clock (it will read it) and will have an interrupt when it's receive buffer is ready. Like I said, it's what I'd *prefer*. Doesn't mean it's possible in MMBasic. :)
Posted: 10:42am 30 Apr 2022
I2C is nice, but it is a local bus. Unreliable over distance. But picomites interconnect through I2C may give you a way to distribute algorithms over multiple cores. A kind of multitasking.
Like a power analyzer use 1 pico to measure 3 phase voltage on its 3 adc and process (fft, rms) And anothe to do the same for the 3 phase current. And a 3rd to provide user interface.
The system would use I2C to communicate and 1 separate sync signal to synchronize the 2 measurement picos.
Edited 2022-04-30 20:47 by Volhout
