Local Time 05:08 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : picoMite VGA my fake SPRITES approach via BLIT need advice
Amnesie
Posted: 10:33pm 21 Apr 2022
Hello everyone,
as I am progressing in learning BASIC, I am aware of the fact that we can not use SPRITES (sadly), so I tested a different approach with BLIT. I was sitting the whole
day for this little program, it works but I am asking if there is a simpler method with less code.
What this program does:
It draws a cursor in the foreground which is a framed BOX, while in the background is an image loaded with lots of different patterns. So normally you would do this with SPRITES.
You can navigate the cursor with the arrow keys like a computer mouse cursor. Later on I want to build some kind of GUI application. Maybe one can use it as a base for a point and click game?
Here is my code:
'Testprogram which displays a cursor that can be navigated via
'arrow keys while on the background is a complex image
CLS
Option Explicit
MODE 2
Dim integer cursorX=100, cursorY=50, cursorXold=100, cursorYold=50
Dim string keyPressed
Dim integer lastCursorKey
Load image "background"
'MAIN LOOP #######################################################
 readKeystroke
Loop
Sub readKeystroke
 keyPressed=Inkey$ 'Get keystroke
 If keyPressed=Chr$(130) Then 'Left Arrow Key is pressed!------------------
  If lastCursorKey = 131 Then 'LastCursorKey: Right
   cursorX=cursorX-20
  EndIf
  If lastCursorKey = 128 Then 'LastCursorKey: Up
   cursorY=cursorY+10
   cursorX=cursorX-10
   Blit Write #1,cursorXold,cursorY,10,10
   Blit Close #1
  EndIf
  If lastCursorKey = 129 Then 'LastCursorKey: Down
   cursorY=cursorY-10
   cursorX=cursorX-10
   Blit Close #1
  EndIf
  If cursorX<>cursorXold And lastCursorKey<>128 And lastCursorKey<>129 Then
   Blit Close #1
  EndIf
  Blit Read #1,cursorX,cursorY,10,10
  Box cursorX,cursorY,10,10,1,RGB(black)
  cursorXold = cursorX
  cursorX=cursorX-10
  lastCursorKey=130
 EndIf
 If keyPressed=Chr$(131) Then 'Right Arrow Key is pressed!------------------
  If lastCursorKey = 130 Then
   cursorX=cursorX+20
  EndIf
   cursorY=cursorY+10
   cursorX=cursorX+10
   Blit Close #1
  EndIf
   cursorY=cursorY-10
   cursorX=cursorX+10
   Blit Close #1
  EndIf
   Blit Close #1
  EndIf
  cursorX=cursorX+10
  lastCursorKey=131
 EndIf
 If keyPressed=Chr$(128) Then 'UP Arrow Key is pressed!------------------
   cursorY=cursorY-20
  EndIf
   cursorY=cursorY-10
   cursorX=cursorX+10
   Blit Write #1,cursorXold,cursorY+10,10,10
   Blit Close #1
  EndIf
   cursorY=cursorY-10
   cursorX=cursorX-10
   Blit Close #1
  EndIf
  If cursorY<>cursorYold And lastCursorKey<>130 And lastCursorKey<>131 Then
   Blit Write #1,cursorX,cursorYold,10,10
   Blit Close #1
  EndIf
  cursorYold = cursorY
  cursorY=cursorY-10
  lastCursorKey=128
 EndIf
 If keyPressed=Chr$(129) Then 'DOWN Arrow Key is pressed!------------------
   cursorY=cursorY+20
  EndIf
   cursorY=cursorY+10
   cursorX=cursorX+10
   Blit Write #1,cursorXold,cursorY-10,10,10
   Blit Close #1
  EndIf
   cursorY=cursorY+10
   cursorX=cursorX-10
   Blit Close #1
  EndIf
   Blit Close #1
  EndIf
  cursorY=cursorY+10
  lastCursorKey=129
 EndIf
If keyPressed=Chr$(13) Then ' ENTER Key is pressed!------------------
 If lastCursorKey = 128 Then 'UP
  Box cursorX+2,cursorY+12,6,6,2,RGB(black)
 EndIf
 If lastCursorKey = 129 Then 'DOWN
  Box cursorX+2,cursorY-8,6,6,2,RGB(black)
 EndIf
 If lastCursorKey = 130 Then 'LEFT
  Box cursorX+12,cursorY+2,6,6,2,RGB(black)
 EndIf
 If lastCursorKey = 131 Then 'RIGHT
  Box cursorX-8,cursorY+2,6,6,2,RGB(black)
 EndIf
EndIf
End Sub
Greetings
Daniel
Edited 2022-04-22 08:46 by Amnesie
Kabron
Posted: 06:32am 22 Apr 2022
Where is background?
Amnesie
Posted: 08:15am 22 Apr 2022
On my SD-card (background.bmp)
vegipete
Posted: 03:37pm 22 Apr 2022
If you are not changing the size of the BLIT READ, do you need the BLIT CLOSE?
Amnesie
Posted: 06:29pm 22 Apr 2022
Thank you for this question but I have no clue about how the BLIT actually works. The manual is a bit complicated to understand about this (for me at least). I think I started to close every BLIT buffer, because I had some trouble with ERROR messages. The problem is at this point I don't really understand how it works. Without the closes I only get errors...
Greetings
Daniel
Edited 2022-04-23 04:31 by Amnesie
Posted: 12:17am 23 Apr 2022
BLIT has two modes.
The first reads back the pixels from one area of the screen memory and writes them to another.
The second reads back the pixels from one area of the screen memory and saves them to RAM. A number of screen areas can be saved this way, but uses a lot of RAM. The stored areas can then be copied to any area of the screen. BLIT CLOSE recovers the RAM for normal use. Not closing means more RAM is used up each time you save another and you soon run out.
Amnesie
Posted: 08:41am 23 Apr 2022
Ahh okay, so I've done it right (to close it every time)? Sprites would be more easy, is there any reason to not integrate SPRITES to the picoMite VGA @ Peter? At least one or two sprites would be helpful!
Greetings
Daniel
Edited 2022-04-23 18:41 by Amnesie
vegipete
Posted: 04:57pm 23 Apr 2022
Yes, using BLIT CLOSE is probably correct. I was thinking of SPRITE READ on the CMM2, which will replace a previous image if the size is the same.
Posted: 04:11pm 25 Apr 2022
The RP2040 in the Pico is very short of RAM. Compromises have to be made...
Tinine
Posted: 04:55pm 25 Apr 2022
Just a small, better-efficiency tip:
EndIf
EndIf
EndIf
EndIf
If the value = 128, there's no point in testing for 129,130,131
select case lastCursorKey
 case 128
 case 129
 case 130
 case 131
end select
Craig
Posted: 06:28pm 25 Apr 2022
Also replace:
cursorY=cursorY+10
with:
Inc cursorY, 10
Using INC saves a variable lookup which is relatively expensive. There is no explicit DEC command, just suppy INC with a -ve argument.
Tinine
Posted: 06:39pm 25 Apr 2022
  thwill said  Also replace:
cursorY=cursorY+10
with:
Inc cursorY, 10
Ah, nice one...thank you
I remember reading about this, many moons ago but I recently looked for it in the manual and didn't find it. Must've been an out-of-date manual.
Craig
Amnesie
Posted: 08:57pm 25 Apr 2022
Thanks both of you for the great tips and hints! :)
Greetings
Daniel
