Local Time 05:08 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/PicoMiteVGA V5.07.03 -PicoCFunctions.h - fix
disco4now
Posted: 11:13am 21 Apr 2022
The updated PicoCFunctions.h header file used for CSUB creation in the V5.07.03 distribution is missing one of the previous fixes that corrected an error in the uSec() function that caused it to hang.
It should be as below in red. Currently has (unsigned int) which had previously been corrected to be (unsigned long long)
//Macros to call each function.
//#define uSec(a)         ((void (*)(unsigned int )) Vector_uSec) (a)
#define uSec(a)           ((void  (*)(unsigned long long )) Vector_uSec) (a)
F4 H7FotSF4xGT
