Local Time 12:26 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Running the STM32L4 board in low power mode
OA47
Posted: 10:04am 13 Apr 2022
My current project is using the Nucleo L4 board and the E-paper display to monitor the battery usage in my caravan. I have chosen this combination for 2 reasons. Firstly I have them not in use and secondly I want to minimize the amount of power drawn from the battery set.
I have a couple of questions that shedders may be able to help me with. Firstly as I cant run the L4 with a voltage above 12V what regulator should I use to minimise the current draw during sleep mode. Secondly can the red LEDs be disabled with software rather than the soldering iron?
OA47
