Local Time 05:28 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Play Sound
cosmic frog
Posted: 03:24pm 10 Apr 2022
Hi all.
I can't seem to get the PLAY SOUND to play Noise.
I can get it to play S(SINE WAVE) Q(SQUARE WAVE) etc, but cannot get anything when trying N(NOISE) or P(PERIODIC NOISE)
PLAY SOUND 1,B,"N",220 - Gives nothing!
PLAY SOUND 1,B,"S",200 - Plays a sine wave as expected.
PicoMite 5.07.03
any ideas?
Dave.
Edited 2022-04-11 01:32 by cosmic frog
vegipete
Posted: 03:34pm 10 Apr 2022
Get rid of the quotes around the N.
Posted: 03:37pm 10 Apr 2022
If you are talking about the PicoMite then these are not supported - they use too much memory. The manual is wrong and needs correcting
cosmic frog
Posted: 03:39pm 10 Apr 2022
  vegipete said  Get rid of the quotes around the N.
Hi Vegipete.
You have to have the quotes or you get an error:Expected a string.
Dave.
cosmic frog
Posted: 03:41pm 10 Apr 2022
  matherp said  If you are talking about the PicoMite then these are not supported - they use too much memory. The manual is wrong and needs correcting
OK. Thanks. No problem.
vegipete
Posted: 03:46pm 10 Apr 2022
Sorry, I was testing on a CMM2.
