OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1051
Posted: 03:26am 08 Apr 2022
I have a PicoMiteVGA and have the setting OPTION SYSTEM I2C GP0,GP1 but I noticed that I cannot start it without the RTC. Is there a way of disabling OPTION SYSTEM I2C without having to reprogram the Pico?
(I did look at the manual but could not locate a reference to an undo statement)
OA47
Sorry about the multiple posts but when I posted the first two I got a fatal error and assumed it didn't upload Edited 2022-04-08 13:28 by OA47
Posted: 03:52am 08 Apr 2022
It looks like OPTION RTC AUTO Disable fixes my issue.
OA47
Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10043
Posted: 07:20am 08 Apr 2022
Yeah, sometime the technology-gods throw a spanner in the works like that. I've locked the other two threads. Glad you got it sorted. Edited 2022-04-08 17:21 by GrogsterSmoke makes things work. When the smoke gets out, it stops!
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11890
Posted: 08:04am 08 Apr 2022
This is a bug. It should start regardless. The issue is that it is trying to write an error message before MMbasic has started up and so locking up. Will fix.
