Local Time 05:28 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : File Manager for picoMite
Amnesie
Posted: 03:51pm 06 Apr 2022
Hello again,
is there a File Manger for the picoMite available? I remember the "File Manager 2"
for the CMM2, but this won't run on the pico... I tried to convert it to the pico, but with no success, since it is too different and I am not an expert. All I got converted was the line command and deleted some obsolete colour modes but after that I got in trouble with "Drive" command ... and the list goes on and on.
But maybe I am missing something and there is a different file manager I might not know of...
Greetings
Daniel
Posted: 04:25pm 06 Apr 2022
Nope, it doesn't have one. It would probably be overkill. Why would you need one?
Amnesie
Posted: 04:38pm 06 Apr 2022
I am using the picoMite VGA as a stand-alone computer and it would be handy, but no problem, when time has come I try to make my own. Til then I still have much to learn :)
Greetings
Daniel
Edited 2022-04-07 02:39 by Amnesie
Posted: 05:03pm 06 Apr 2022
It's a bit restricted as to what you can do when you look at the hardware.
FILES is reasonably powerful and easy enough to use.
