Local Time 22:39 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 G1 parts available
Posted: 07:58am 05 Apr 2022
I have surplus CMM2 parts for sale.
This is the CMM2 Generation 1
Waveshare module. New with the latest CMM2 firmware loaded. It has a V revision chip so will run at full speed.
Circuit board V2.1 This board has the provision for the 8MHz oscilator mod and mainly through-hole components.
8MHz oscillator module
Both USB ports.
Battery holder.
2mm pitch sockets for the Waveshare module.
Will not split and prefer ship to AUS due to postage rates for overseas.
Price $75 express postage included.
TasOak
Posted: 11:01pm 27 Aug 2023
  TassyJim said  I have surplus CMM2 parts for sale.
Both USB ports.
Battery holder.
Hi TassyJim,
I know I may be a bit late on the uptake, but do you still have the Waveshare module/kit for sale?
I have bought one of the last 2 CMM2 gen1 short kits from SC in the hope that someone else may have the CPU module for sale.
I am a new member and this is my first post/response. I was just getting started with MM back in 2012 but suffered a bad fall and have only recently returned to the Microprocessor world. Catch-up is such fun🙃
TasOak/Glen
Posted: 12:17am 28 Aug 2023
Welcome to the forums.
If Jim cannot help, I can:
I have three, two still sealed in their original bags.
The one out of the bag, will have some version of the firmware in it already.
I never bothered to offer these on my website, or even here on the forums, as I expected no-one wanted them anymore, with the all-in-one PCB design being the default standard, and the gen1 design not really desirable - up until the chip shortages during COVID.
If you or anyone else is interested, send me a PM and we can make a deal.
Happy to ship overseas at your cost.
Posted: 05:44am 28 Aug 2023
Yes,
Still available at the same price.
While the smd g2 version is nice, at least with these units, you can change components. I have a couple which are unrecognizable due to the 'mods' I have done.
TasOak
Posted: 06:54am 28 Aug 2023
  TassyJim said  Yes,
Hi Jim,
PM on the way
Glen/TasOak
TasOak
Posted: 06:55am 28 Aug 2023
Thanks Grogster,
PM on the way.
Glen/TasOak
Posted: 07:50am 28 Aug 2023
Those pics have made me quite nostalgic, with memories of soldering those 2mm connectors and having to do the clock mod later. :)
I always liked the plug-in module version too, Jim. You can connect to things. :)
Posted: 07:55am 28 Aug 2023
Sold.
TasOak
Posted: 11:49pm 31 Aug 2023
  Mixtel90 said  Those pics have made me quite nostalgic, with memories of soldering those 2mm connectors and having to do the clock mod later. :)
I will need the details of this mod, hope I can find some in the forum, it is a very busy place😃
Glen/TasOak
Posted: 06:46am 01 Sep 2023
You'll only know if you need the mod when you come to test the graphics modes. Some people are lucky and everything is fine, I wasn't (as expected....  :( ). By then, of course, everything is soldered in.
From "CMM2_G1_Construction Guide.pdf":
External Oscillator
The latest PCB has provision for an external 8 MHz crystal oscillator to replace the 8 MHz crystal on the Waveshare CPU board. This may be needed in some rare cases where a monitor has difficulty with some VGA modes (such as 800x600 pixel 16-bit colour).
Most people will not need this modification however, if it is required, it can be implemented by installing the external oscillator and a capacitor on the motherboard (under the Waveshare CPU board). The 8MHz crystal on the Waveshare board does not have to be removed.
The parts required are:
1 SMD 1206 100nF ceramic capacitor
1 8MHz oscillator in 5.0 x 7.0 mm SMD package (QX7 XO 25ppm). Eg, RS Stock Nbr 813-6194.
Edited 2023-09-01 16:53 by Mixtel90
Posted: 07:08am 01 Sep 2023
As shown in the photos, the board I supplied has the pads for the oscillator and I have supplied the required oscillator.
I would strongly advise that the oscillator is used.
Posted: 08:28am 01 Sep 2023
Oh yes - It hadn't dawned on me that it was in the pic! - Need to clean specs more often. :(
+1 It's almost certainly easier to install before the adjacent connector!
TasOak
Posted: 08:48am 01 Sep 2023
Ah🤔Thankyou to Mick and Jim, so the preventative approach is taken to be able to solder in the oscillator without having to desolder the close spaced socket pins.
Makes sense to me, thanks again to you both.
Glen
Posted: 11:59am 01 Sep 2023
You don't need to unsolder the connector anyway (thank goodness!), but it's fiddly.
TasOak
Posted: 06:20am 06 Nov 2023
Having been on the road since before these toys were delivered, thanks to both TassieJim and Grogster, all safe and sound.
I have just finished building the first CMM2 G1, as the waveshare module was already programmed, I managed to bring it to life immediately, very satisfying
Things started going sour fairly quickly when i started typing in a program, the "" key was producing @@ symbols, but luckily the reverse was simply that, and Tera Term was producing the correct result, not perfect, so i started chasing the latest firmware.
easy to find
Next comes STM32CubeProgrammer v2.14.0, and that's where it all stops, programmer wants
to communicate with STM server, ok, but it insists on a Proxy, nothing else will do, I have changed the proxy setting in the program to None and done the same in win10, still no communication, restarted programs and computer.
What am i missing? the program says it needs server comms to download updates, but its the latest edition anyway, so I suppose its to get chip specific data.
Is there an alternative or do I start setting up a Proxy server for my home internet?
too much time away from a computer is not good for senior brains
Posted: 09:51am 06 Nov 2023
Other tools include
dfu-util
OpenOCD
stlink
stlinkv2
qstlink2
pystlink
st-flash
TasOak
Posted: 10:07am 06 Nov 2023
thanks JohnS, looks like I have some investigating for tomorrow.
There are some interesting variations on a theme there, think I'll just start at the top and see what happens
Glen
Posted: 10:05pm 06 Nov 2023
I use Cube to program all the CMM2's I setup here, and it never asked for a proxy....
It DID force me to jump through a couple of email hoops before you can download the program itself, but once you have done that, I just run the programmer and away you go.
Perhaps you could post a screen-shot of the message you are getting?
Posted: 10:53pm 06 Nov 2023
  Quote  the "" key was producing @@ symbols
Set your keyboard to US and that will be fixed.
Like Grogster, I have never had problems with Cube programmer
TasOak
Posted: 11:00pm 06 Nov 2023
Humble pie please, a generous serve.
Whilst Cube complains of a lack  of connectivity due to proxy server issues, one need only get on with the programming aspect and all goes according to Geoff.
It’s probably good that it cannot communicate anyway, and being a fresh download it’s the latest version already.
Now to get on with the next lesson😁
Glen
Ps. Thanks for the keyboard tip, it was difficult to look past the glitch, but all ahead full now👍
Edited 2023-11-07 09:05 by TasOak
