Local Time 05:34 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite I2C BME280
grroel.tech
Posted: 12:02pm 27 Mar 2022
Hello,
I have connected an I2C DHT22 temperature and humidity sensor to the RPi Pico according to the instructions in the Picomite manual. It works perfectly. But I would also like to monitor the atmospheric pressure, as I have done with other controllers with a BME280 sensor.
Could you show me the necessary code using the I2C interface?
Thank you very much.
Posted: 12:11pm 27 Mar 2022
Google would have found
http://www.thebackshed.com/forum/ViewTopic.php?TID=8362
amongst others
