Local Time 05:34 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite I2C
circuit
Posted: 12:57pm 21 Mar 2022
I have assembled a PicoMite with an SSD1963 screen and PS2 keyboard.  All running well, operating with the SSD1963 in console mode and the touch interface and SD card interfaces are all fine.  I have configured I2C on GP20 and GP21 and linked up to a Micromite 170 to add extra outputs.  I pasted the following code into the slave Micromite, taken from Geoff's Micromite Getting Started book.
'I2C slave board program - outputs only
OPTION AUTORUN ON
SETPIN 2, DOUT 'Set up test pin and check it is working
PIN(2)=0
PAUSE 500
PIN(2)=1
PAUSE 500
PIN(2)=0
DIM msg(2) ' array used to hold the message
I2C SLAVE OPEN &H26, 0, 0, WriteD, ReadD ' slave's address is 26(hex)
DO ' the program loops forever
WATCHDOG 1000 ' this will recover from errors
LOOP
SUB ReadD ' received a message
I2C SLAVE READ 3, msg(), recvd ' get the message into the array
IF msg(0) = 1 THEN ' command = 1
SETPIN msg(1), msg(2) ' configure the I/O pin
ELSEIF msg(0) = 2 THEN ' command = 2
PIN(msg(1)) = msg(2) ' set the I/O pin's output
ELSE ' the command must be 3
    s$ =
STR$(PIN(msg(1))) + SPACE$(12) ' get the input on the I/O pin
ENDIF
END SUB ' return from the interrupt
SUB WriteD ' request from the master
I2C SLAVE WRITE 12, s$ ' send the last measurement
I only want to be switch outputs on and off on the slave, therefore the code running in the PicoMite master;
' I2C Routines on Master to operate pins on a slave MicroMite
' Taken from "Getting Started"
SetPin gp20, gp21, i2c
I2C open 100,1000
SLAVEPIN 2, 1
Print "ON"
Pause 2000
SLAVEPIN 2, 0
Print "OFF"
Pause 2000
Loop
' set the output of an I/O pin on the slave
Sub SLAVEPIN pinnbr, dat
I2C WRITE &H26, 0, 3, 2, pinnbr, dat
If MM.I2C Then Error "Slave did not respond"
End Sub
When I run both codes, the master runs okay but the slave reports
   [23] I2C SLAVE READ 3, msg(), recvd ' get the message into the array
   Error : Cannot find RECVD
   Watchdog timeout
   Processor restarted
What AM I doing wrong?  I am sure there is a simple answer but I have been banging my head against this all weekend.
Posted: 01:26pm 21 Mar 2022
  Quote  What AM I doing wrong?
You need to DIM (or LOCAL) the variable recvd before it is used (must be a float)
circuit
Posted: 08:03pm 21 Mar 2022
Peter, thank you for you most speedy reply.  I copy/pasted the code directly from the manual - does this need correction?  This is the same code that appeared originally in v. 4.5 Micromite Manual and then was migrated over to the 'Getting Started with Micromite' manual - of which there have been several revisions.  Has no-one come across this issue before?
Posted: 08:19pm 21 Mar 2022
I suspect the default would have been a float back then.
Now it will depend what else you have in your program, I think.
