Local Time 13:08 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Where Does MMBASIC for DOS Store Files????
jwettroth
Posted: 06:11am 18 Mar 2022
This might be a bone headed question but I'm stumped!
I am writing some MMITE code but the beginning of the code was sort of user console where I would let the user set options, etc and then time out and run the regular code if no console was connected in the embedded version.  I used MMBASIC for DOS 5.05.05 an d got my little console dialog working to my satisfaction in DOS.  I figured I would then put it into the main embedded code but I can't find it.  If I start mmbasicdos, I can load it, edit and run it- but I can't find it.  I have saved it and its not gone, I just can't find it.
Please be gentle if this is the dumbest problem ever but I'm lost.
John Wettroth
toml_12953
Posted: 06:21am 18 Mar 2022
From a DOS prompt do this:
cd \
dir yourprogname /s
DOS will search all directories (that's what the /s is for) to find the file.
Posted: 06:27am 18 Mar 2022
WEDIT will open Notepad with the loaded file in it. Use "Save As" to put a copy in a location of your choice.
Or try:-
SAVE "C:\path\file.BAS"
Can't Windows Search find it?
jwettroth
Posted: 06:38am 18 Mar 2022
Thank you!
I'm of a certain age and relied on DOS for many years but forgot about /s switch.
It found it!
Its in "my user name\AppData\Local\Virtualstore\Program Files (x86)\MMBASIC" wow
Is this documented?
John Wettroth
jwettroth
Posted: 06:42am 18 Mar 2022
Windows search was of no use.  I tried to do a save to C:\, root of C:, no joy.
I appreciate the help.
John Wettroth
Posted: 06:47am 18 Mar 2022
"Is this documented?"
Searched the manual but can't find it.
Tested WEDIT and that works.
Posted: 06:53am 18 Mar 2022
  jwettroth said  Thank you!
It found it!
Is this documented?
It looks like you installed MMBasic.exe into program files.
NOT a good idea
put the exe into a folder that is NOT in program files such as C:\apps\MMBasic
That way Windows will behave nice.
jwettroth
Posted: 06:55am 18 Mar 2022
WEDIT Didn't work for me- If I rerun MMBASIC and do a load- all works.
If I do a WEDIT, it says file not found.
It must have been the way I started the file.  I was trying to try out some commands and just started typing into the MMBASIC dos console.  After I got a handle on things, I just used the MMBASIC editor until I got to a certain point.  I then was going to merge the code into my embedded app inside of Notepad++ but ran into this weirdness.
Thanks very much Phil99 and toml_12953- this is an amazing group- its after 1 am, I get stumped, put a question on line and have a solution in 20 minutes- amazing!
John Wettroth
jwettroth
Posted: 07:02am 18 Mar 2022
Wow- thank you Tassy Jim- just trying to keep my root directory Tidy
I get it and I had no idea of this odd behavior but it now makes perfect sense.
Thanks - I repeat "best user group ever!"
John Wettroth
Posted: 07:05am 18 Mar 2022
"If I do a WEDIT, it says file not found."
Were you trying that at the DOS prompt? My bad I should have said it is a MMBasic command ie you use it at the MMBasic command prompt.
jwettroth
Posted: 07:10am 18 Mar 2022
phil99- thanks for the help- WEDIT is a cool feature.  I guess I have to move MMBASIC out of the program files folders- Windoze treats this differently and does funny things- thanks Tassy Jim.  Learned something.
John Wettroth
