Forum Index : Microcontroller and PC projects : The Pico is doomed
| Page 1 of 5 |
| led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 210 |
Interesting... Pico Doom led Miss you George |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10109 |
This is amazing, and just goes to show how powerful that tiny little 2040 chip can be! Link about developing and squeezing it into the limited RAM of the PICO... YouTube video from the OP link.. That they were able to port this game to the PICO's relatively low RAM specs, is fascinating, and just shows how useful those PIO's are!!!! Smoke makes things work. When the smoke gets out, it stops! |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9329 |
Sheesh!!!!!! That's simply stunning! With I2C networking for up to four players too... It goes to show what can be done when you use all the resources of that chip (with some really neat data compression). There are some *very* clever people around. :) Edited 2022-03-16 17:33 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Great demo video. But what I find amazing is that their website spends a lot of time talking about how they built the game but there are no practical details. For example, what are the pinouts for the VGA? And the Audio? Game play keys? And so on. I could not even find a compiled .uf2 file. I guess that you need to be a C++/Pico/Doom expert and dig through the source yourself and compile your own version. In that case this just an exercise in hubris and making a great looking demo video. What a pity if that is true. If anyone does find a detailed description of how to wire it up please post it here - I was looking forward to trying it out. Geoff Geoff Graham - http://geoffg.net |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12185 |
https://github.com/kilograham/rp2040-doom/releases/tag/v0.1 Designed to run on this Note he is clocking the Pico at 270MHz so may not run on all boards UPDATE Load the 4Mb uf2, you need a usb keyboard connected to the PICO USB port so will need other power. I've got it up and running - very very impressive Edited 2022-03-16 18:23 by matherp |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6254 |
Absolutely fabulous. I am impressed to read how far this guy (team) has gone to proof it is possible. They actually changed everything from the vanilla game and used compression on about everything they could, just to fit it in RAM (and ROM). This is really impressive. And all this for a one-off (well, potentially 3-off: Heretic and Wolfenstein will be simple now, but then it ends...) In retrospective .... I ran DOOM on a 66MHz 486.... With double 270MHz ARM cores doing video generation and audio you should be able to isolate 10% of that power to run the game itself and achieve similar game experience. The challenge was not the CPU power but the memory restrictions .... A fantastic achievement. PicomiteVGA PETSCII ROBOTS |
WOW. John |
Excellent Peter, thanks. The hardware is not too expensive so worth buying outright. Geoff Geoff Graham - http://geoffg.net |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4410 |
Damn, and I'd gone a whole month without buying a piece of electronics gubbins. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
They must use GP20 and GP21 for the I2C interconnect in multiplayer. PicomiteVGA PETSCII ROBOTS |
Too bad.... It's like smoking.... very addictive... PicomiteVGA PETSCII ROBOTS |
The thing is, is using an I2C sound chip cheating? ;) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Michal Senior Member Joined: 02/02/2022 Location: PolandPosts: 125 |
Or maybe someone would be tempted to write an IBM PC/XT emulstor? In the end, it's 128kB RAM, 4.77MHz and CGA. Michal |
The board has PWM audio PicomiteVGA PETSCII ROBOTS |
The code uses the DAC on the board not PWM struct audio_i2s_config config = { .data_pin = PICO_AUDIO_I2S_DATA_PIN, .clock_pin_base = PICO_AUDIO_I2S_CLOCK_PIN_BASE, .dma_channel = 6, .pio_sm = 0, }; |
I'm amazed that they put in such a huge effort to write a brilliant program and then leave people to dig through the code to figure out details like this. Geoff Graham - http://geoffg.net |
I just accept that all such things are done through profound wizardry, Geoff. I know nothing of these C magik spells (and not much of anything else either!). :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
I suppose people could read the copious documentation. I suspect not everything someone might ask is yet in there, but that has applied to every system's documentation I've ever met I think, MMBasic included. John |
Just got it up and running myself - absolutely no fuss. It's amazing what the little Pico can do. Peter given this board is available off the shelf (and it sounds like you have one) have you considered a PicoMite port/fork for it ? - the answer "No" is fine, you can't port to everything. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Port in what sense? I'm wondering what features in particular? (Obviously not the graphics etc which use both cores flat out highly overclocked and all the RAM & flash.) John |
| Page 1 of 5 |
