Local Time 13:08 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : new win10 setup and Stop error code 0x0000007B
Plasmamac
Posted: 02:31pm 11 Mar 2022
to find out what exactly Frank N.Furters Problem with MM4bW is , i setup a new win10
installation . ( i mean he have the dll but it shows allready the error)
mmb4w trow some msvc40 errors and finally a Stop error code 0x0000007B !
copy the dll will not help : install visual studio 2022  !!
works fine now .
dunno it it fits the winmm.dll problem also .
hope it help.
mfg
Edited 2022-03-12 00:33 by Plasmamac
Plasma
Posted: 02:38pm 11 Mar 2022
Not my area of expertise, but I am nevertheless confident that if you are running a program built with VS 2022 and not statically linked then you need the appropriate redistributable package installed:
https://docs.microsoft.com/en-US/cpp/windows/latest-supported-vc-redist?view=msvc-170
The majority of MMB4W users aren't seeing this issue because some other (properly packaged and not slung on its own in a .zip file ) application has already installed a compatible redistributable package.
I may of course be completely wrong,
Plasmamac
Posted: 04:00pm 11 Mar 2022
all i can say is after installing the studio the stop error is gone
Plasma
Posted: 04:01pm 11 Mar 2022
  Plasmamac said  all i can say is after installing the studio the stop error is gone
Yes, funnily enough I imagine it includes everything contained in its corresponding redistributable .
Posted: 08:43pm 11 Mar 2022
The first thing to look for is a "Microsoft Visual C++ xxxx Redistributable (x86)"
I would expect that it is one of them that's missing but don't know what version.
