Forum Index : Microcontroller and PC projects : bug in the picomite (or the manual)?
| jovian Regular Member Joined: 16/04/2017 Location: AustraliaPosts: 63 |
Loving the Picomite thanks all! FYI Manual on VAR SAVE states: "Also, the saved variables will be automatically cleared ... when a new program is loaded via AUTOSAVE" Except they don't get cleared. Totally screwed me up for a couple of hours... javascript:AddSmileyIcon(' ') |
Ah, that is the behaviour in the Micromite. Peter, what happens in the PicoMite? The manual might need changing. Geoff Geoff Graham - http://geoffg.net |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11892 |
I'll make the code match the manual. Won't be until next week. The FLASH commands won't clear saved variables but the other commands as in the manual will |
