Local Time 00:04 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Dragging an image with mouse with frame sync
William Leue
Posted: 04:52pm 09 Mar 2022
I am trying to get dragging an image with a mouse working without annoying flickering.
I have tried both sprites and blitting from page 1, but both have the screen refresh artifacts. I can't find any way to draw a small image with explicit frame synchronization. I know that page copy does have a frame sync option, but I don't want to draw the entire screen, just move a small image around.
Apologies if this has been covered before; please point me toward a post.
Thanks!
-Bill
vegipete
Posted: 04:59pm 09 Mar 2022
CMM2?
I've had mixed results using GETSCANLINE.
Also, the MODE command has an optional interrupt parameter - maybe useful.
William Leue
Posted: 05:08pm 09 Mar 2022
Yes, sorry: CMM2
-Bill
William Leue
Posted: 05:12pm 09 Mar 2022
Thanks for the info, vegipete! I think I might be able to get it to work using the mode 'int' param, which I have never noticed before.  I can see why trying to use GETSCANLINE would be wonky.
-Bill
William Leue
Posted: 05:31pm 09 Mar 2022
Hmm, well I tried using the 'int' parameter on the MODE command, but it seems as if the routine that gets called from the MODE 'int' is suppressed while the mouse button is down. Or at least that is the symptom: when the mouse button is held down, the image that I want to drag does not move, and then reappears at the new mouse position when the button is released. The only place I do any drawing is in the MODE interrupt routine, which gets passed the mouse x, y location in the mouse left click interrupt routine.
I'm guessing that MMBasic only has one level of interrupts available, so the mouse interrupt preempts the MODE one.
-Bill
Posted: 05:40pm 09 Mar 2022
  Quote  The only place I do any drawing is in the MODE interrupt routine,
You should never do anything substantial in an interrupt routine. Just set a flag and then do the work elsewhere. If you want to do stuff while the mouse is pressed then I personally wouldn't use interrupts at all but rather poll for the mouse press.
Also make sure that you aren't continuously updating the image. Make sure that you only do it if the mouse has moved by a non-trivial amount
mode 1
page write 1
box 0,0,50,50,5,rgb(red),rgb(blue)
sprite read 1,0,0,50,50
controller mouse open 0
cls
do
lastx=x
lasty=y
x=mouse(x,0)
y=mouse(y,0)
if abs(x-lastx)>=2 or abs(y-lasty)>=2 then sprite show 1,x,y,1
page copy 1 to 0,b
loop
Edited 2022-03-10 04:00 by matherp
William Leue
Posted: 06:16pm 09 Mar 2022
Thanks for the good advice, Peter! I will try those ideas.
-Bill
Posted: 08:39pm 09 Mar 2022
My sliderule works happily doing full page copies.
SUB moveslide
IF slidepos <> oldpos OR cursorpos <> oldcursorpos THEN
  SPRITE HIDE 4
  IF slidepos <> oldpos THEN SPRITE SHOW 3, slidepos, ABline, 0
  SPRITE SHOW 4, cursorpos,Tedge-5,0
  oldpos = slidepos
  oldcursorpos = cursorpos
  PAGE COPY 1 TO 0 ,b
ENDIF
END SUB
Full program:
https://www.c-com.com.au/mmhelp/sliderule.htm
It's 12 months since I have done any changes so might have missed out on a few firmware improvements but still seems to move smoothly for me.
vegipete
Posted: 09:08pm 09 Mar 2022
PAGE DISPLAY could be useful too, using page flipping.
