Local Time 05:46 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Stereo audio out sockets....
Posted: 05:33am 04 Mar 2022
Hi all.  I have run out of these, and Mouser - who I normally get them from, don't have any either.  They are expecting another 9000 or so in May, but I need some now.
Do any of you have some spare?
I only need four to complete my hand-assembled CMM2's using the ARM chips I have here.
Once they are all built and sold, I won't be making any more for at least a year till I can get more ARM chips, and by then, interest will probably have dropped off, so I expect these to be the last four I ever sell.  Probably.
Can anyone help?
al18
Posted: 05:46am 04 Mar 2022
I realize I'm on a different continent than you, but if you're looking for a thru hole 3.5 mm stereo socket, Mouser has over 5000 in stock of P/N 490-SJ1-3525NG-GR at $0.84 each
Posted: 05:59am 04 Mar 2022
If it's the same as the V1, RS and Element14 have stock
Switchcraft 35RASMT4BHNTRX
RS is very expensive, Element14 much better.
Posted: 06:57am 04 Mar 2022
@ al18: Thanks, but no - that is completely the wrong connector.
@ Jim: Yes, that is the correct part.  Agree that RS are excessively priced, and element14 have some stock, so I will get four or six from them - thanks.
al18
Posted: 07:56am 04 Mar 2022
Ok - I see your board uses a surface mount connector. FYI Digikey also has stock of the Switchcraft connector mentioned above.
Posted: 08:17am 04 Mar 2022
Cool, thanks, and no offense intended.
Welcome aboard the SS BackShedForums though.
Posted: 10:27am 04 Mar 2022
I can help you out grogs,
PM me if still interested.
I probably have 30 or more left
