Local Time 06:06 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite and MMEDIT problem
Gillis55
Posted: 09:32am 15 Feb 2022
Hi Gurus,
As a change from the Micromites I've successfully used in the past, I've just received a PicoMite to play with and I now have it working quite nicely via some simple programming with TeraTerm.  If my understand is correct, I assume MMEDIT may also be used so I thought I'd give it a try but no joy.  The version of MMEDIT I'm using is V4.1.4 on WIN10 and it appears to connect to the PicoMite via USB but I get no CR prompt response with MMChat.  If I disconnect and then reconnect I do get the > prompt appear in the output window but still no response using the MMChat command line.
With my Micromite programming, I like using MMEDIT and it would be good if I can also use this with the PicoMite. So, any help you can offer would be much appreciated.
disco4now
Posted: 09:39am 15 Feb 2022
Check you have latest MMEdit 4.x, There was an updated DLL to make it work with Picomite if I remember.
F4 H7FotSF4xGT
palcal
Posted: 07:05pm 15 Feb 2022
You may have MM.Edit still set for Micromite you have to set it for Armmite H7.
Posted: 08:26pm 15 Feb 2022
  disco4now said  Check you have latest MMEdit 4.x, There was an updated DLL to make it work with Picomite if I remember.
That is the correct answer.
The pico needs DTR asserted and that is what the new DLL does.
My website was updated mid-December.
Edited 2022-02-16 06:27 by TassyJim
Gillis55
Posted: 05:34am 18 Feb 2022
Guys,
As you kindly advised, I've now updated to the latest MMEDIT version V4.1.4 OS10 8-12-2021 and set it to Picomite.  MMEDIT is now working very well with my PicoMite which is great.  Thankyou all.
Edited 2022-02-18 15:37 by Gillis55
