Local Time 06:06 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pi Bare Metal
lew247
Posted: 05:37pm 12 Feb 2022
I have been doing a lot of research and I found the following information
IF anyone is interested in trying to make an MMBasic Pi Bare Metal Port
I'm not saying it's possible, but it looks like it might be, I just don't have the knowledge to do it myself
What started me looking was the fact that CircuitPython on Raspberry Pi (Bare Metal / No OS) can be run on the following Pi boards:
Raspberry Pi Zero W
Raspberry Pi Zero 2 W
Raspberry Pi 4 Model B - 2 GB RAM
Raspberry Pi Compute Module 4 IO Board
Raspberry Pi Compute Module 4 - 4GB RAM, 32GB MMC and WiFi
The information for that is here
I then done more searching and I found the following
MicroPython on bare metal Raspberry Pi Zero / Zero W / 2 here
Quick reference for the Raspberry Pi Zero W MicroPython here
Bare Metal Wi-Fi driver for the Raspberry Pi
The latest Linux Wi-Fi driver for the Pi by the manufacturer of the chip used here
Datasheet for the Wi-Fi/Bluetooth chips used in the Raspberry Pi in  the Pi Zero W [https://www.infineon.com/dgdl/Infineon-YW43438_Single-Chip_IEEE_802.11_b_g_n_MAC_Baseband_Radio_with_Integrated_Bluetooth_5.1_Compliance-AdditionalTechnicalInformation-v14_00-EN.pdf?fileId=8ac78c8c7d0d8da4017d0ee1ee20680a]here
Datasheet for the Wi-Fi/Bluetooth chip in the Pi 3B+ here
Software and tools Raspberry Pi Wi-Bluetooth here contains several
this for Pi Zero
drivers.zip
Anyone able to make anything out of them?
Posted: 05:51pm 12 Feb 2022
It's a pity that none of the bare metal CircuitPython supported boards appears to be available ...
Michal
Posted: 06:02pm 12 Feb 2022
There was (and is still alive) such an interesting project Ultibo (microkernel compiled in fpc). It is a pity that it is little known.
I think he just ran out of a built-in Interpreter for some language.
Michal
Posted: 06:13pm 12 Feb 2022
There doesn't seem to be much bare metal stuff for the Pi boards. I think Peter has a good point - what you write for one won't run on the next version, especially if the GPU or Broadcom SOC has changed. A minor change in the GPU can stop the Broadcom booting at all.
Posted: 06:24pm 12 Feb 2022
Lewis
Anyone can look up the references and it is almost certainly do-able.
HOWEVER, my estimate would be 500-1000 hours of work (my hours). It is vanishingly unlikely that anyone is going to take it on. Some time ago someone contacted me via Geoff with a view to a joint effort on a bare metal port. I said no and he said he would take it on himself - that was 2 years ago.....
Feel free to keep raising it but there are few TBS members who could do it and fewer still with the time and probably none with the inclination
Michal
Posted: 06:47pm 12 Feb 2022
  matherp said  HOWEVER, my estimate would be 500-1000 hours of work (my hours).
And the implementation of your version (for Windows) on Debian is a very big effort?
Michal
Edited 2022-02-13 04:48 by Michal
Posted: 06:48pm 12 Feb 2022
  matherp said  Feel free to keep raising it but there are few TBS members who could do it and fewer still with the time and probably none with the inclination
For what it's worth I'm with Peter. I'm really quite an accomplished C programmer and I suspect by cribbing from other bare metal Pi projects I could fill in the missing pieces of hardware knowledge in my arsenal. Even so I would double Peter's estimate and at 10 hours a week available for such a project on my best week I'd probably be looking at 3+ years, potentially many more ... ain't going to happen .
Edited 2022-02-13 04:50 by thwill
Posted: 06:55pm 12 Feb 2022
  Quote  And the implementation of your version (for Windows) on Debian is a very big effort?
About 50 hours so far and other than sound all the hard stuff is now done
Edited 2022-02-13 04:56 by matherp
Michal
Posted: 07:14pm 12 Feb 2022
wow!
Can we expect your Debian (hopefully also on Raspberry) version in the near future?
Michal
Posted: 07:16pm 12 Feb 2022
  Quote  Can we expect your Debian (hopefully also on Raspberry) version in the near future?
No: I don't do Linux but its a simple WIN32 app so I assume it should "Wine"
Edited 2022-02-13 05:28 by matherp
Posted: 07:43pm 12 Feb 2022
One question (not to imply that I have any interest in doing the work): is "bare metal" the same on the Pi-ZW and the the Pi-Z2W and PIs 3 & 4?
Posted: 08:07pm 12 Feb 2022
  Quote   is "bare metal" the same on the Pi-ZW and the the Pi-Z2W and PIs 3 & 4?
No: and that is a major issue. Each one is a different port
lew247
Posted: 02:20pm 13 Feb 2022
Does the Kernel contain the information (drivers) for the board?
or what does it actually contain?
Posted: 02:55pm 13 Feb 2022
A linux kernel usually contains some of the drivers (basic display, keyboard, mouse but it can be a lot more), but not all. Exactly what is in it depends on what was included when it was compiled so it can vary.
  lew247 said  Does the Kernel contain the information (drivers) for the board?
If you mean Linux kernel, effectively yes.  (And all the painfully different hardware is effectively coped with there.)
Bare metal of course has no Linux kernel/drivers & would have to re-do all that stuff.
Posted: 03:01pm 13 Feb 2022
  Michal said  And the implementation of your version (for Windows) on Debian is a very big effort?
Michal
If you consider
1. a version (for Windows)
and
2. on Debian
Then #1 would be huge had it been bare metal, but isn't because the OS does so much.
#2 depends either on WINE or on compiling/linking with code which mimics whatever APIs etc Peter has used.
Edited 2022-02-14 01:02 by JohnS
lew247
Posted: 04:29pm 13 Feb 2022
So If we had the "bare metal" Kernal used for the Pi Zero W,Pi Zero 2 W and the Pi 4B then we could use that IF anyone was to try and port MMBasic?
Posted: 04:59pm 13 Feb 2022
If you know what drivers are in it and how to use them it would be a start. Then you need the specific drivers for each of those boards.
True bare metal doesn't need drivers but in practice you don't know how to use the GPU or the Broadcom chip and at least some of that info isn't available unless you sign NDA agreements. Hence you will probably need at least some of the firmware from Raspberry Pi. That will be in the form of libraries that may or may not be published. Not only that, but the different boards don't use the same chipset - or they may do but with different parts/modes enabled by Broadcom.
The best you'll probably manage is with a stripped down kernel. Take out everything that's not needed to make it ultralight then write for that. It's not bare metal but at least you stand a chance of getting something to work. Even then, there's no official way (yet) to give access to the GPIO at user level, only as root. That's not safe.
It was so much easier when CPU manufacturers went out of their way to give you lots and lots of information on their products!
Michal
Posted: 05:14pm 13 Feb 2022
The Ultibo I mentioned, created such kernels:
30-10-2021  04:32         3115720 kernel.img
30-10-2021  04:32         3156720 kernel7.img
30-10-2021  04:33         3181616 kernel7l.img
Michal
Posted: 05:35pm 13 Feb 2022
I think RPi list a minimal kernel. I'm pretty sure they used to anyway. There's no desktop or anything.
