Local Time 06:06 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Unpaired Brackets Box Command-
Chopperp
Posted: 01:35pm 10 Feb 2022
Hi
A quick query.
I added a couple of Boxes (for Bar graphs) on a CMM2 program & they worked as expected.
I ran Jim's variable report in MM E V5 & it came up with a couple of unpaired brackets on the Boxes code.
I removed the offending brackets & the Boxes behaved the same.
Just wondering why they worked with the extra brackets?.
The two lines below show the original with the extra bracket on the RGB  bits & the other line without them for one of the Boxes.
WN_01_Batt is a number between 10 & 15
BOX 282, 102, (WN_01_Batt - 10) * 24, 11, 1, RGB(180, 180, 180)), RGB(180, 180, 180))
BOX 282, 102, (WN_01_Batt - 10) * 24, 11, 1, RGB(180, 180, 180), RGB(180, 180, 180)
Brian
ChopperP
Posted: 02:37pm 10 Feb 2022
MMBasic uses ad hoc parsing rather than an explicitly grammar-driven tool.
So long as it is "good enough" do you care...
Posted: 08:41pm 10 Feb 2022
An extra closing bracket doesn't seem to cause grief.
An extra opening bracket will not be so forgiving.
MMEdit just counts them all and expects an equal count for opening and closing.
Chopperp
Posted: 02:09am 11 Feb 2022
Thanks John & Jim
ChopperP
