Local Time 13:49 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Video output
dmasz
Posted: 09:02pm 07 Feb 2022
Hello,
PicoMiteVGA really rules :-) and this gets me to question:
Would it be possible to generate Video Signal to connect PicoMite to Reverse Camera Monitors. as it is great source for cheap displays.
br
Daniel
hitsware2
Posted: 09:37pm 07 Feb 2022
I think they use composite vs. vga signal ....
my site
Posted: 09:39pm 07 Feb 2022
Most of those monitors, as far as I can see, only accept composite video. Connecting to a Pico would require a video standards converter or a complete rewrite of the Pico video section.
Peter has said the Pico is complete, no more major work so the latter is unlikely, thus you will need to research the former.
led-bloon
Posted: 03:19am 08 Feb 2022
VGA to Composite
About halfway down is a circuit using the AD724 chip and a few passive components
(ignoring the bottom half of that circuit!)
I have no idea if that chip is available, or how well it works, but the it looks
interesting.
led
Miss you George
Posted: 06:24am 08 Feb 2022
I'd simply use a VGA-to-composite video converter.
They can be had for about $15 or so.
VGA-to-AV converter
retepsnikrep
Posted: 06:41am 08 Feb 2022
A MMBasic Geoff project directly generating composite video has been done before IIRC.
I really like those backup camera monitors, cheap and nicely cased.
Gen1 Honda Insights.
Posted: 06:48am 08 Feb 2022
Yes, composite B/W video only though.  Not colour.
That was the Maximite generation 1, or the ASCII terminal.
dmasz
Posted: 09:05am 08 Feb 2022
Yes. B/W is more that enough.
RPi Pico generating composite video + Backup Camera Monitor + few relays will make nice package to controlling and display parameters with easy on the field possibility
to adjust code thanks to MMbasic.
maybe Peter will unfreeze, some day, RPi Pico project and will add that option to firmware or it will be 3rd firmware flavor.
br
Daniel
Posted: 09:22am 08 Feb 2022
I know it's an extra box, but the little converters are usually pretty good (I used a VGA-HDMI one for years when I had a non-HDMI monitor). You have to house the PicoMite somewhere so why not take a converter to bits, do away with the plugs & sockets and put it in the same box? People wanting HDMI output could do a similar thing. The case used for the CMM2 should be big enough, I think. Even the case mentioned some time ago that takes a PCB about 100mm square might be suitable.
Of course, if you want a control system you might be better using a SSD1963 5" or 7" display to get the touch screen. I know you don't get the fancy case,  but I assume that you're going to want controls.
Posted: 03:09pm 08 Feb 2022
The used 640x480 monochrome video mode is around the native visible area of a PAL screen. It may be posible to use the composite sync mode, some resistors, and maybe tune the framerate to 50hz.
When my pico arrives, i'll look into it.
My experience with the vga cvbs convertors, om a larger tv, is not that good. But it may be fine for a car monitor.
EDIT: WON'T WORK. PAL and NTSC are interlaced at 15.6kHz. VGA is most likely 32 kHz
Edited 2022-02-09 01:24 by Volhout
