Local Time 13:49 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ARM H7 and Directory name strangeness?
KeepIS
Posted: 04:30am 05 Feb 2022
First off: I can't reload earlier firmware at this moment in time and I'm not even sure this is a firmware issue.
ArmmiteH7
V5.07.01b0.bin
Firmware Version  5.0701
None of these directory names have underscore chars, and when the SD card is viewed in Windows, they show correctly without an Underscore char. Just for the hell of it I went through and renamed each directory with NO underscore char.
SD card returned to the ARM H7.
1: Directory list retrieved by MMBasic DIR$ command and displayed with the Text command.
M 02 D 04
M 02 D_05  *** underscore added
M 01
M_02 D_03  *** two added
2: Same as above but with the SORT command used before the Text display.
M 01
M 02 D 04
M 02 D 05  <- now ok
M_02 D_03  *** still underscore
3: Same above but files inside the Directory, displays space after DF correctly.
DF 07-55.dat
DF 08-35.dat
DF 09-54.dat
DF 10-34.dat
DF 12-48.dat
DF 13-08.dat
4: Using the Files command at the Command prompt, space are replaced with underscore
A:/LOG_2022
  <DIR>  M_01
  <DIR>  M_02 D_03
  <DIR>  M_02 D_04
  <DIR>  M_02 D_05
4 directories, 0 files
5: Same as above but files inside the Directory, displays space after DF correctly
A:/LOG_2022/M_02 D_05
13:22 05-02-2022      49648  DF 07-55.dat
13:22 05-02-2022      49648  DF 08-35.dat
13:22 05-02-2022      49940  DF 09-54.dat
13:22 05-02-2022      49649  DF 10-34.dat
13:21 05-02-2022      49644  DF 12-48.dat
13:21 05-02-2022      49648  DF 13-08.dat
0 directories, 6 files
The file names in step 5 match file names in step 3.
Thoughts?
BTW the directory names and file names are being created by MMBasic on the Arm-H7, not on a Win PC. However they all display correctly on Win PC.
Edited 2022-02-06 08:18 by KeepIS
NANO:Inverter V 8.4ksLinux AvrDude GUI script V4.1
