Local Time 14:03 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Oddity with FOR/TO loops
Goksteroo
Posted: 01:47am 01 Feb 2022
I was messing around with some old Spectrum Benchmark programmes - stripping line #s, removing goto's, etc and then testing the results on CMM2, newest MM Basic for Windows, and an Amstrad emulator. Why? Because I was curious. The programme tests loops, maths, etc over a 10 second period and counts number the of loops performed as a score.
Curiously for/to loops performed slower in MM basic once line #'s were removed and it came down to how the NEXT statements were written:
               MMB - Win      MMB - CMM2
NEXT i:NEXT j  - 239,133   -  14,092  loops
NEXT i,j       - 154,177   -  10,713  loops
NEXT:NEXT      - 371,976   -  26,316  loops
Lesson there for anyone who uses lots of nested for/to loops in their programs.... but otherwise just a quirk in MM Basic.
BTW - the Amstrad CPC managed 20 loops in the same 10 second period!
Geoff aka Goksteroo
hitsware2
Posted: 03:36am 01 Feb 2022
( Perhaps ( probably ) ) from abject ignorance ,
I have always thought line numbers an elegance .
my site
toml_12953
Posted: 05:12am 01 Feb 2022
  hitsware2 said  ( Perhaps ( probably ) ) from abject ignorance ,
They were necessary in the days of teletypes and dumb terminals in order to be able to get meaningful error messages and allow easy editing such as inserting new lines between other lines. In fact they're still required by the ANSI/ISO standard for Full BASIC.
Posted: 08:03am 01 Feb 2022
whatever floats your boat. They have their place I think, certinly as "tell-tales" for debug and error handling.
I wrote VB (as a job) for years and I used line numbers scattered through the code to break up the program into logical chunks (not every line, key points and I called them steps though) so when errors were logged in the wild I had a really good idea what was going on at the time.
Like this:
3100:
               Set TRS = DBCONN.Execute(SQL)
               G = TRS.GetRows
3110:
               For n = 0 To UBound(G, 2) ' each ci in buffer for this sysident
                   InitCI (n)
                   ' here we have a sanitized CI so check if it exists
... so any error reported in "step" is 3100 will be associated with that DB access.
I went on to provide a similar debugging method (because TRON is unfathomable) in MMBasic which makes life a lot easier when debugging
http://www.fruitoftheshed.com/MMBasic.Program-Step-A-Fast-Flexible-Debugging-Aid.ashx
Edited 2022-02-01 18:30 by CaptainBoing
Posted: 08:37am 01 Feb 2022
Strangely enough, an almost identical concept is described in my ancient "Basic - Faster And Better & other mysteries" book for the TRS-80. He says that line numbers should be used as subject and paragraph headings and that the Renumber command is probably the worst thing you can use. He has a very good point. Interchangeable blocks of code (taken from your "stock"), doing similar things, share the same block of line numbers as you'll only use one of these blocks in a program.
