Local Time 06:26 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Transparent Sprites on the CMM2
daveculp
Posted: 02:12pm 26 Jan 2022
Im at my wits end with transparent sprites, looking for some help.
Im getting back to CMM2 programming and decided to try making a simple game.  Ive got a starfield which is just three arrays holding X,Y and color data for three levels of a parallax style star field.
I have a player sprite which is just a spaceship cut from a sprite from the free sprite_lib library https://www.widgetworx.com/spritelib/.
I set mode 1 at the start and go. I draw small circles where the "stars" are and then draw the sprite, all on page 2 then I do a page copy to page 0. Everything works great except I cannot for the life of me get transparent pixels on the sprite. I'm not looking for semi-transparency, just a standard sprite in which certain pixels are transparent and let things in the background show through.
I have saved as a PNG with both transparency data and with the transparent pixels set to 0,0,0 RGB.  I use SPRITE LOADPNG to the load it and it  never works, even tried out different graphics modes.
I use GIMP to edit the sprite.  I THINK the problem may lie in the format GIMP uses to save the image data.
Any tips?
Posted: 03:44pm 26 Jan 2022
Are you in a 12-bit colour mode? Transparency only works in 12-bit colour with page 0 and page 1 used for the two layers. Check the manual for more details
Edited 2022-01-27 01:44 by matherp
daveculp
Posted: 05:11pm 26 Jan 2022
I did try 12 bit color depth and got the same results.  I did read the manual and the manual on graphics programming.
I was under the impression that 12 bit depth transparency was mostly for making semi-transparent objects like in the ghost demo but every mode could support sprite transparency in which RGB(0,0,0) was not drawn, meaning it would be "transparent".
vegipete
Posted: 06:10pm 26 Jan 2022
Can you try to just LOAD PNG on a convenient page, then SPRITE READ to 'sprite-ify' the  rectangle of interest?
daveculp
Posted: 06:17pm 26 Jan 2022
  vegipete said  Can you try to just LOAD PNG on a convenient page, then SPRITE READ to 'sprite-ify' the  rectangle of interest?
I will give that a try tonight!
Posted: 06:37pm 26 Jan 2022
RGB(0,0,0) is always black. If you use that for a sprite it's on an opaque black background.
You need a PNG with "chequerboard" background, indicating that it's transparent. That's in ARGB4444.
daveculp
Posted: 06:55pm 26 Jan 2022
  Mixtel90 said  RGB(0,0,0) is always black. If you use that for a sprite it's on an opaque black background.
I will see if GIMP will save in ARGB4444 format.  Page 37 of the graphics programing document stated that the ideal format was ARGB8888 so I was using that.
Edited 2022-01-27 04:57 by daveculp
Posted: 07:09pm 26 Jan 2022
As far as I was concerned that was the "hard" book. :)
daveculp
Posted: 07:28pm 28 Jan 2022
I got simple Sprite transparency working on all color depths using a PNG in ARGB8888 format by using SPRITE WRITE instead of SPRITE SHOW.
