Local Time 06:37 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Geoff's ASCII terminal, revisited
Posted: 04:07am 11 Jan 2022
just happened upon the below while looking for something completely unrelated:
https://github.com/petrohi/terminal
(upgraded firmware with menu setup, 640x480, 60Hz VGA output)
https://github.com/dhansel/TerminalUSB
(added USB keyboard support via USB port)
https://github.com/bkw777/Geoff_vt100
(looks like PCB only)
https://github.com/legacypixels/terminal
(largely same as petrohi's but more recent activity)
the upgrade of the firmware to support USB keyboard directly looks interesting, this could be an open-source replacement to the commercial solution that the CMM2 mk2 has a socket for.
note: i've not looked into any of the above in great detail.
rob   :-)
Edited 2022-01-14 23:04 by robert.rozee
