Local Time 06:48 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : pico as a 6-port USB to serial bridge
Posted: 05:16am 05 Jan 2022
there was mention in another thread of extra virtual serial ports on a pico, and it reminded me of the below:
https://github.com/harrywalsh/pico-hw_and_pio-uart-gridge/tree/HW_and_pio_uarts
six physical serial ports (RxD and TxD only) concentrated by a pico onto a USB bus, with 6 virtual comm ports then available at the PC end.
one could argue that this is the 2nd most useful thing to do with a pico (sitting a good distance below running MMbasic on it). there is a compiled binary for this somewhere out there on the net, but i can't quite remember where. although it may well benefit from updating to use the latest SDK.
rob   :-)
Posted: 07:38am 05 Jan 2022
Good find.
This is really nice. I will try this tonight. A pico acts as 6x FTDI.
They use the PIO's though, so I expect the baudrate of PIO UARTS to be coupled, not independent.
Edited 2022-01-05 17:39 by Volhout
Posted: 08:24am 05 Jan 2022
saw a design for something similar back in the late 80s. of course it wasn't as compact but it was a RS232 pass-thru and the designer used a higher baudrate to communicate with the controller and switch port, the higher rate being ignored by the attached peripherals.
never built one but I liked the idea of addressable '232
