Local Time 07:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : serial output and aliases
gingpeakin
Posted: 03:57pm 27 Dec 2021
Apologies if I've missed something but I am new to MMbasic.  I am very familiar with PIC Basic (Proton).
I have 2 question - can I name a pin with an alias? Rather than pin(gp21) = 1 I would rather write either pin(LED) = 1 or better still LED = 1.
Also how can I write to a serial port single bytes or collections of bytes or variables as bytes rather that ASCII characters as seems to be the case with print #1, <stuff>
Ging
Posted: 06:03pm 27 Dec 2021
First:
const REDLED = 4, GRNLED = 8
pin(REDLED) = 1
pin(GRNLED) = 0
Second:
AFAIK when you use PRINT # it always converts your variable to text.
nbr1 = 123, nbr2 = 456
open "numbers.txt" for output as #1
print #1, nbr1
print #1, nbr2
close #1
will produce the file numbers.txt
open "numbers.txt" for input as #1
line input #1, a$
line input #1, b$
close #1
x = VAL(a$): y = VAL(b$)
will make x=123 and y=456
Posted: 06:15pm 27 Dec 2021
  Quote  Also how can I write to a serial port single bytes or collections of bytes or variables as bytes rather that ASCII characters as seems to be the case with print #1, <stuff>
See the BIN2STR$ function in the manual
Posted: 06:36pm 27 Dec 2021
Also CHR$()
gingpeakin
Posted: 11:53am 28 Dec 2021
Thanks everyone.  I've now got
Const IrisPin = 31  'GP26_A0
SetPin Irispin,ain
SetPin gp0,gp1,Com1
Open "Com1:9600" As #1
Iris = pin(Irispin)      'variable Iris has the value of A0
Iris - Int(Iris * 30.2)  'turns value into 0 to 100
Print #1;Bin2str$(int8,iris);
and it does what I need - a single byte decimal value 0 to 100.
Posted: 12:06pm 28 Dec 2021
Or
Print #1;Chr$(iris);
hmm, usually (other BASICs) a comma:
Print #1, Chr$(iris);
Edited 2021-12-28 22:07 by JohnS
