Local Time 07:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ESP01 WIFI
georgestheking
Posted: 10:01am 25 Dec 2021
Pico is very nice but we do not have wireless communication.
The Cytron Maker Board for example has a option for an ESP01 chip.
It will be so nice to have a wifi library for a standard ESP01.
And as all the IOT board use MQTT protocol.
MQTT support  will be the Nirvana.
Any code yet avalable ?
Best regards
Happy new years for all menbers
Georges
flasherror
Posted: 02:03pm 25 Dec 2021
I feel the best way to implement this is to have MMBASIC support ESP8266 AT command firmware. Although it wasn't there some time ago (when I was experimenting with AT firmware) it looks like newer AT firmware supports MQTT.
Anyone else willing to help on this? I'd like to help make this a reality.
References:
https://docs.espressif.com/projects/esp-at/en/release-v2.2.0.0_esp8266/
https://docs.espressif.com/projects/esp-at/en/release-v2.2.0.0_esp8266/AT_Command_Set/MQTT_AT_Commands.html
Edited 2021-12-26 00:11 by flasherror
Posted: 02:16pm 25 Dec 2021
  georgestheking said  ... The Cytron Maker Board for example has a option for an ESP01 chip.
Miltel90's Pico PCB and my Pico PCB have options for an ESP-01 module. See PCBs at Pico on fruitoftheshed.
The MQTT AT command set looks interesting.
Edited 2021-12-26 00:17 by lizby
georgestheking
Posted: 07:33pm 25 Dec 2021
Thanks for these information.
That is very good news.
If ESP01 have MQTT AT command that is all I need.
I order pieces today to try it.
Best regards
Georges
dMajo
Posted: 11:35pm 25 Dec 2021
Have a look also at this module and dev. board (RP2040+ESP8285):
Wio RP2040 Module
Wio RP2040 mini Dev Board
ALLdataEE.com  EDU Promos
