Local Time 07:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite question to users
Posted: 04:16pm 21 Dec 2021
I've been doing some experimenting while programming the VGA version.
It transpires that saving the Basic program in flash memory and running it from there has only a minimal impact on performance - around 10% maximum. Most of the critical bits of the MMBasic firmware are copied to RAM so in normal use the flash cache would then be nearly all available to the Basic program, hence the minor speed impact
Doing this would allow Basic programs to increase in size to close to 160Kb with a concomitant increase in variable memory to the same amount. The number of flash slots available for storing programs would reduce from 10 to 5.
The confusing OPTION MEMORY command would be removed
Is this the correct approach for the next release?
Cyber
Posted: 04:33pm 21 Dec 2021
"allow Basic programs to increase in size to close to 160Kb" - sounds good to me.
"number of flash slots available for storing programs would reduce from 10 to 5" - I am okay to sacrifice.
"confusing OPTION MEMORY command would be removed" - also sounds good to me!
Do you plan doing this changes for VGA version only or for original PicoMite as well?
_
Edited 2021-12-22 02:43 by Cyber
Posted: 05:10pm 21 Dec 2021
Hmmm...
IMHO 10 flash slots is really nice if you are running without an SD card. It keeps it nicely self contained. So I don't know really...
Posted: 06:04pm 21 Dec 2021
  Quote  Do you plan doing this changes for VGA version only or for original PicoMite as well?
Definitely for the VGA to overcome the loss of memory to the framebuffer. The question is about the PicoMite original
Tinine
Posted: 08:17pm 21 Dec 2021
@Matherp
"Concomitant"! Holy cr@p, you swallowed a dictionary?
I like the idea of 160K. Yes, the slots are cool but can be clunky when the program exceeds 80K.
Posted: 09:31pm 21 Dec 2021
"ooh! you can't do that Les, it's not conducive, it's not concomitant!"... was a catchphrase from some 70s sit-com... but I can't remember which
Tinine
Posted: 09:47pm 21 Dec 2021
@CaptainBoing
"70s sitcoms"   Buddy suggested "Alf Garnett TV repair" on YT. How the heck that's survived the woke-brigade beats me.
Posted: 11:07pm 21 Dec 2021
Reducing the number of flash slots need not be a problem. More than one program can be put into each slot.
On the MM2 and MM+ I use the library to store several short utility programs by turning them into subroutines. The first line in them is "Clear" to remove old variables. At the command prompt you just type their name and they run.
Even on the MM F4 (no library) they can be put at the end of the main program, and it works just as well.
The main program in that slot could be a menu to make it even easier.
Edited 2021-12-22 09:10 by phil99
Posted: 12:11am 22 Dec 2021
hi peter,
  +1 for running basic programs directly from flash.
would it be worthwhile thinking about making the flash slot sizes variable, to allow maintaining the current number? not quite a full 'file system', but perhaps have a pool of 240 2k blocks (with a 240 entry 'allocation table') which are allocated to flash slots as needed.
rob   :-)
electricat
Posted: 06:45am 24 Dec 2021
+1 for performance
Most interesting problems/projects seems to be time related (emulations, measuring and feedback, calculations, user interfaces etc.)
10 slots for CHAIN or PROGRAM looks pretty well balanced already :-)
My MMBasic 'sand box'
Posted: 08:35am 24 Dec 2021
  Quote  +1 for performance
Too late
V5.07.03 PicoMite
Maximum program size now 124Kbytes, Flash slots reduced from 10 to 7.
Program now runs from flash memory freeing up much more memory, following tuning there is no significant impact on performance
V5.07.03 PicoMite VGA
Maximum program size now 108Kbytes, Flash slots reduced from 10 to 8.
Tinine
Posted: 10:58pm 24 Dec 2021
@matherp
Nice compromise
Man, this stuff just keeps getting better.
Cyber
Posted: 05:30am 25 Dec 2021
matherp, so there will always be two releases for PicoMite: regular and VGA.
Do you have source code well organized, so common code of these releases is not repeated? Ir is it not that great?..
Posted: 09:14am 26 Dec 2021
  Quote  Do you have source code well organized, so common code of these releases is not repeated? Ir is it not that great?..
What are you implying
There is a single source with two make files. All differences between the versions are driven by a single global define
