Local Time 07:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Compare Bugs ?
georgestheking
Posted: 07:24am 21 Dec 2021
I try to check if a number is ODD or EVEN using PICOMITE 5.07.01
dim integer I,P
dim float F
for P=0 to 15
I=P/2
F=P/2
if I=F then print "ODD"
else
print "EVEN"
endif
next
I get always ODD !
What is wrong ?
Thanks for your help
Georges
Edited 2021-12-21 17:35 by georgestheking
georgestheking
Posted: 07:45am 21 Dec 2021
After a lot of testing I found that this version is working
dim integer I,P
dim float F
for P=0 to 15
I=P/2
F=P/2
if I=F then
print "ODD"
else
print "EVEN"
endif
next
Posted: 07:58am 21 Dec 2021
An observation.
On an F4 I get this:-
> for p%=0 to 15 :i%=p%/2 : f=p%/2 : if f=i% then : print "odd" : else : ? "even" :endif : next
odd
even
odd
even
odd
even
odd
even
odd
even
odd
even
odd
even
odd
even
But on a Pico this:-
Error : Cannot find a matching FOR
Same sort of error if I try a Do...Loop Until - no matching Do
Pico not quite the same as the rest in Immediate Mode. No loops it seems.
Posted: 08:00am 21 Dec 2021
The close of the loop is only being executed as part of the If. Strange that it is not being picked up in both versions.
as to the original inquiry; for integers you can use a bitwise AND (very fast, and a bit faster still if you specify the radix):
If (P And &h1) Then 'odd
for (whole number) floats you can say
If (P/2)<>Int(p/2) Then 'odd
which is pretty much what you were doing anyway but avoids mixing datatypes (here be dragons).
Edited 2021-12-21 18:38 by CaptainBoing
georgestheking
Posted: 08:03am 21 Dec 2021
Nice Tricks Captain,
Thanks,
That's perfectly correct.
IF test THEN process
is an abbreviation that can be on a single line only because there are no alternatives.
Unabbreviated it would be
IF test THEN
 process if passed
END IF
the correct form of the command with an alternative is
IF test THEN
 process if passed
ELSE
 process if failed
END IF
wolfme
Posted: 08:56am 21 Dec 2021
Another way (and in one line):
For r%=0 To 15 : If r% Mod 2 Then Print "odd" Else Print "even" : Next r%
your code from above should be like this on pico:
For p%=0 To 15 :i%=p%/2 : f=p%/2 : If f=i% Then Print "odd" Else Print "even" : Next
EDIT: it seems that your code from above ist wrong, it prints the opposite (1 is even, 2 is odd and so on)
Edited 2021-12-21 19:08 by wolfme
Posted: 12:42pm 21 Dec 2021
"Pico not quite the same as the rest in Immediate Mode. No loops it seems."
Found the problem.
Line length too long, despite all characters showing on the screen some were being lost. Using OPTION DISPLAY 50,120 fixed it.
wolfme
Posted: 01:36pm 21 Dec 2021
aaah, ok. You typed in to command line.
I always use option display 50,132 thats maximum i think.
Posted: 02:01pm 21 Dec 2021
  phil99 said  "Pico not quite the same as the rest in Immediate Mode. No loops it seems."
Found the problem.
This is interesting. I've encountered this error, but never figured out the reason, so thank you.
Posted: 08:21pm 21 Dec 2021
 dim integer P
 for P=0 to 15
   if p mod 2 then
     print p,"ODD"
   else
     print p ,"EVEN"
   endif
 next p
RUN
0   EVEN
1   ODD
2   EVEN
3   ODD
4   EVEN
5   ODD
6   EVEN
7   ODD
8   EVEN
9   ODD
10    EVEN
11    ODD
12    EVEN
13    ODD
14    EVEN
15    ODD
