Local Time 07:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Comm Port Still open after Watchdog timeout
OA47
Posted: 09:24pm 19 Dec 2021
Does anyone have any ideas how I would get around this situation on a ArmMite F4 running MMB5.5?
Watchdog timeout
SDLogFile= Created 00:20:10 20-12-2021
SDCard Ready
TEST MODE = OFF
201221 002012 From PC: 15
[390] Open CFN$ For Append As #4
Error: File number already open
OA47
Edited 2021-12-20 07:28 by OA47
Posted: 09:47pm 19 Dec 2021
Could you trap the watchdog timeout using ON ERROR SKIP nn then check MM.WATCHDOG to see if you've had a watchdog timeout. If you have then close all files and ON ERROR ABORT cleanly.
Posted: 10:00pm 19 Dec 2021
on error skip
if mm.errno <> 0 then ' do something
Edited 2021-12-20 08:02 by lizby
Tinine
Posted: 06:07am 20 Dec 2021
Is there any harm in simply closing it before opening or will that throw an error (don't have a MM in front of me to test)?
Posted: 06:41am 20 Dec 2021
"closing it before opening or will that throw an error (don't have a MM in front of me to test)?"
From memory it does. 2 solutions
1
on error skip
close #4
2
Open it before the loop so there is something to close on the first pass.
OA47
Posted: 11:58pm 20 Dec 2021
Here is the amended code I have implemented, fingers crossed.
     If MM.Info$(SDCARD)="Ready" Then
       Pin(PA6)=0
       On Error Skip
       Close #4
       If MM.Errno <> 0 Then
       EndIf
       Print #4, ScrnMsg$
       Close #4
       Pin(PA6)=1
     Else
       GUI DELETE SVE
       GUI BUTTON SVE, "SD ERROR",230, 20,80,20,RGB(RED), RGB(yellow)
     EndIf
Thanks for the help shedders.
OA47
Posted: 12:44am 21 Dec 2021
" If MM.Errno <> 0 Then"
Is this needed? Either it has just been closed or was never open, either way it can now be opened.
OA47
Posted: 01:29am 21 Dec 2021
  Quote  " If MM.Errno <> 0 Then"
It is needed as if you try to close an already closed port you get an error.
> close #1
Error : File number is not open
OA47
Tinine
Posted: 04:48am 21 Dec 2021
Trying to figure how that would be useful.
Pretty certain that an already closed port in MS BASIC doesn't complain....I could be wrong though.
Posted: 06:20am 21 Dec 2021
The purpose of the
On Error Skip
is to prevent the next line stopping the program.
Manual Page 140
ON ERROR SKIP will ignore an error in a number of commands (specified by
the number 'nn') executed following this command. 'nn' is optional, the default
if not specified is one. After the number of commands has completed (with an
error or not) the behaviour of MMBasic will revert to ON ERROR ABORT.
Tinine
Posted: 07:07am 21 Dec 2021
  phil99 said  The purpose of the
On Error Skip
Manual Page 140
Understood but why would MMBasic care if a port was already closed?
If I set an output-bit low, for example, I don't get a "output already low" if I do it repeatedly.
Just trying to imagine a context where it would protect/prevent something naughty.
Posted: 07:20am 21 Dec 2021
"why would MMBasic care if a port was already closed?"
That is a good question, but it does so there must have been a reason.
For OA47's purpose On Error Skip should sidestep the issue.
Posted: 08:49am 21 Dec 2021
  Tinine said  Trying to figure how that would be useful.
+1
always been a mystery to me... If it's closed and your intention is to close it - who cares if it's already closed? I suppose it gives the possibility of fine(r) control over a system (and it plays to my "you decide how to handle stuff" - don't like languages to make assumptions) - am I reaching?
I don't remember this throwing an error on any flavour of basic I used, but I could easily be wrong.
EDIT: QB45 definitely didn't. I found this the other week... bemused by what my thinking must have been when I wrote it 30+ years ago.
If QB did the "file already closed" thing, this would have been a solid error throw. And it wasn't.
Edited 2021-12-21 19:02 by CaptainBoing
Posted: 12:54pm 21 Dec 2021
In Explicit Mode that is the case, but otherwise all sorts of default assumptions are made. That is one of the advantages of BASIC, you don't have to specify every little detail if you know the defaults.
Posted: 08:14pm 21 Dec 2021
In PureBasic there are functions like isSerial() for you to test before trying to open or close.
If IsSerialPort(#MaximitePort)
   CloseSerialPort(#MaximitePort)
 EndIf
In Liberty Basic, I had to keep flafs to prevent erors when closing
if TooltipsOnMM=1 then re=ReleaseTooltipMemory(hTipMM)
   if configWin=1 then close #config
   if chatWin=1 then close #chat
   if mmchat=1 then re=disconnectSER(connectionID) ' close #MM
In MMBasic, I am happy using flags or 'on error skip'. The choice is yours.
ON ERROR SKIP is more robust when trying to recover form system crashes.
Tinine
Posted: 08:30pm 21 Dec 2021
@TassyJim
Devil's advocate: Isn't there the possibility of skipping a legitimate error, though?
Posted: 09:05pm 21 Dec 2021
  Tinine said  Devil's advocate: Isn't there the possibility of skipping a legitimate error, though?
You can always do
Tinine
Posted: 09:55pm 21 Dec 2021
You can always do
Pretty mind-blowing just how much they crammed in to this thing.
