Local Time 14:59 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB4L: XModem questions
Posted: 01:57pm 12 Dec 2021
Hi folks,
Work proceeds on serial support for MMB4L, I've got it working sufficiently so that I have been able to write an MMBasic program "Gonzo" that runs on MMB4L and allows me to communicate with a tethered CMM2 or PicoMite:
Welcome to gonzo v2.0.0-a1
Connecting to /dev/ttyS0: 115200 ...
Connected to Colour Maximite 2 G2
gonzo$ help
Commands are:
 break       send a Ctrl-C to the remote
 connect     connect to remote
 device      report type of connected device
 exit        exit the gonzo shell
 help        display help text
 log         show (or clear) receive log
 rchdir      change remote directory
 rcopy       copy a remote file
 rdelete     remove a remote file or (empty) directory
 receive     receive a file from the remote using AUTOSAVE
 rfiles      list remote directory contents
 rmkdir      make a directory on the remote
 rpwd        display current remote directory
 rrename     rename a remote file or directory
 rsize       display size of a remote file
 rtype       list remote file contents
 send        send a file to the remote using AUTOSAVE
 term        open serial terminal
 version     display current gonzo version
 xreceive    receive a file from the remote using XMODEM
 xsend       send a file from to the remote using XMODEM
gonzo$
But I have a couple of questions about XModem (using code borrowed from the CMM2 originally by Georges Menie):
1. Is it expected to be so damn slow ? about 7 times slower than transferring using AUTOSAVE; though more flexible since AUTOSAVE expects only ASCII.
2. Is there anything the SENDer can do to cleanup the padding appended to a file sent via XMODEM or do I need to do any cleanup on the RECEIVEr ?
Posted: 02:28pm 12 Dec 2021
1. From my experience XMODEM should run at about the same speed as AUTOSAVE.
2. The convention was that the padding char should be EOF (CTRL Z).  The old DOS software would use that as an end of file marker.  So it is the receiver that has to cleanup.
Edited 2021-12-13 00:29 by Geoffg
Posted: 02:32pm 12 Dec 2021
generally the sender will pad the file being sent to a multiple of 128 bytes with chr$(0)'s. the receiver can then strip out any chr$(0)'s that it finds.
it works extremely quickly for me, and is surprisingly simple to use (well, with GFXterm at least). it should operate at about the same speed as AUTOSAVE, as the data transferred is 99% just the text of the original ascii file with a header (3 byte) and footer (1 byte checksum) attached.
i've not tried using XMODEM for anything other than text, am not really sure the original designer ever though about this. with binary data you'd not really be able to determine how many of the chr$(0)'s at the end were padding.
feel free to have a look at the GFXterm source code for a very simple XMODEM implementation. have been hacking the code a bit, so see attached for the latest version:
xmodem.pas.zip
rob   :-)
addendum: SNAP! you were writing at the same time as me, geoff. i think ctrl-Z was the original, but later on chr$(0) was used. i had thought the MX170 used chr$(0).
Edited 2021-12-13 00:47 by robert.rozee
Posted: 03:11pm 12 Dec 2021
Thanks for the input.
At the moment using LIST/AUTOSAVE definitely seems faster, though with a sufficiently large file only ~twice as fast as XMODEM. I'm guessing that the 'mite XMODEM code is doing more processing than the LIST/AUTOSAVE route or I've got some sort of buffering issue.
The implementation of XMODEM on the 'mites appears to use the NUL character for padding but can handle receiving Ctrl-Z, it just translates it to NUL ... except for the CMM2 .
  robert.rozee said  i've not tried using XMODEM for anything other than text, am not really sure the original designer ever though about this. with binary data you'd not really be able to determine how many of the chr$(0)'s at the end were padding.
Yes, I think it will be necessary for Gonzo to send the file-size separately.
  robert.rozee said  feel free to have a look at the GFXterm source code for a very simple XMODEM implementation. have been hacking the code a bit, so see attached for the latest version: xmodem.pas.zip
Thanks but there is no particular reason not to use the standard C 'mite implementation.
Posted: 03:20pm 12 Dec 2021
certainly wouldn't be changing the 'mite code, but the GFXterm code may provide you with some pointers on how the whole XMODEM protocol works. it took me quite a while to get the finer details figured out, although i may have just been looking in the wrong places!
rob   :-)
Posted: 04:37pm 12 Dec 2021
  thwill said  Yes, I think it will be necessary for Gonzo to send the file-size separately.
Which (at least when the remote is a CMM2 with a file-system) proved very easy. After an XMODEM SEND, "Gonzo" now sends a small program "Rizzo" to the remote that strips off the padding - I will probably be debugging this until "kingdom come".
Edited 2021-12-13 03:07 by thwill
Posted: 08:39pm 12 Dec 2021
XMODEM can be padded with either zero or ^Z. Either is considered acceptable.
Unless the receiver knows the true length of the file, there is no way it can strip off the superfluous characters. Just trimming of the ending ^Z (or zeros) is OK for text but can be disastrous for any other file type.
Most image formats etc seem to handle the extra characters without any pain.
If a user writes a program that accepts files that might have been XMODEMed, the user has to make allowances.
While it would be nice if the extras were trimmed, users need to accept that they might be there.
YMODEM solved these issues.
Posted: 09:48pm 12 Dec 2021
  TassyJim said  XMODEM can be padded with either zero or ^Z. Either is considered acceptable.
Unless the receiver knows the true length of the file, there is no way it can strip off the superfluous characters. Just trimming of the ending ^Z (or zeros) is OK for text but can be disastrous for any other file type ...
Thanks Jim. Like I say I've resolved the problem for remote 'mites with file-systems by having "Gonzo" transmit a small utility program "Rizzo" that knows the size and can thus remove the padding.
  TassyJim said  YMODEM solved these issues.
As far as possible, and with the exception of "Rizzo" I'm trying to write "Gonzo" so it uses the serial console to drive standard 'mite features on the remote and doesn't require any additional programs to be installed. I guess this is exactly how MMEdit must be working ?
Edited 2021-12-13 07:48 by thwill
Posted: 09:52pm 12 Dec 2021
  Quote   I guess this is exactly how MMEdit must be working ?
MMEdit's file manager knows the file size so receiving files can be truncated (optionally) but sending to the 'mite is "user beware"
Posted: 09:56pm 12 Dec 2021
Right, same for "Gonzo" when receiving, and "Rizzo" solves the problem when sending, provided the remote 'mite has a file-system.
Posted: 10:30pm 12 Dec 2021
"Most image formats etc seem to handle the extra characters without any pain."
For .BMP at least, file size is in the header so the viewer app ignores anything after that is reached.
