Local Time 07:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : AS5600 Magnetic Rotary Encoder Module
DaveJacko
Posted: 10:12pm 10 Dec 2021
Hi MMBasic friends,
I recently bought an AS5600 rotary magnetic encoder.
Very pleased with it, easy to use (see my code)
As a man who's fitted an accelerometer to the catflap,
I'm always looking for like-minded souls.
( haha!.. think I've found a few in this shed !  )
Can we think of a good application for this module,
maybe a weathervane, or an inverted pendulum..
' AS5600 magnetic rotary encoder DPJ
' 3v3 4096 steps/360 deg
' agc ideally returning about 64
addr=&h36 'I2C address
Dim agc,rah,ral,ang As integer
'ie auto gain control, angle high byte,low byte,result angle
Pause 50 'power-up delay
I2C open 100,100,PU  'set up I2C..
'this is speed kHz,timeout ms, pullup
rdlp:
Pause 100
I2C write addr,0,1,&h1A 'select agc reg
I2C read addr,0,1,agc
I2C write addr,0,1,&h0C 'select raw ang reg
I2C read addr,0,1,rah
I2C read addr,0,1,ral
ang=(rah<<8)+ral
Print ang;"  ";agc;"  ";Chr$(13);
GoTo rdlp
Try swapping 2 and 3 over
Posted: 10:56pm 10 Dec 2021
  DaveJacko said  Hi MMBasic friends...As a man who's fitted an accelerometer to the catflap
Hello and welcome... I am dying here
Posted: 06:59am 11 Dec 2021
  Quote  As a man who's fitted an accelerometer to the catflap,
You just gotta love someone with such dedication!
Tinine
Posted: 08:20am 11 Dec 2021
  DaveJacko said  Hi MMBasic friends,
rdlp:
Pause 100
ang=(rah<<8)+ral
GoTo rdlp
Neat device
For multi-turn, the MCU would need to keep track though, right?
