Local Time 15:13 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : QB64 Revisited
Tinine
Posted: 08:45am 06 Dec 2021
Need to do some BASIC code prototyping but prefer to do it on the PC.
I have DOSBox installed and my MSPDS 7.1 (fancy QuickBasic) but I thought I'd take another look at QB64. I tried it years ago and it felt too darned clunky but now I find it to be really nice. The first time that I compiled/ran (Run or F5) a Hello World in the IDE, it took an eternity but now it's fine.
The IDE, at first, looked like the original DOS screen but I hit Alt/Enter to give me full-screen and changed the font and now it looks great.
The cool thing is that it checks your code as you enter it and the "status" panel tells you what it expects you to type next. Only had an hour with this thing but it's growing on me rapidly
Posted: 09:08am 06 Dec 2021
never played with 6.4 but I did a *LOT* of 5.0 when I was in my early 20s
We ported a lot of our older work to it to leverage the burgeoning PC market and it worked. The snobbery surrounding PCs (it has to be an IBM PC controller or it doesn't even get a look in) allowed us to access bids and markets that were otherwise closed. Thing is the ported software was sometimes at a disadvantage because of the screen modes but otherwise un-modded stuff that was always seen as not good enough became instantly wow just on the basis of the platform.
The compiled nature was very nice, very quick - I even did a primitive text-based windowing environment based on a large array which I copied screen memory to/from.
I was never really comfortable about all the DECLAREs for SUBs at the front of the code - always thought that was a bit clunky
Wow, what a memory trip. Found some of the old code in my deep store... and a part of me wants to port it to a micromite... for no reason at all
SUB ProcessRadarData
       SHARED SampPeriod, TimeChangeFlag, WindPTR, TimeDone, BurstFlag
       SHARED DataPtr, RadarValid, Mode$
       SHARED AzimuthRaw!, ElevationRaw!, RangeRaw!, TimeRaw!
       SHARED TempValid, Mb100PTR
       PutStatus ("Processing Radar")
       IF Mode$ = "T" THEN
               RadarValid = yes
               LOCATE 23, 2: COLOR white, black: PRINT "Tracking"; SPACE$(50);
       ELSE
               RadarValid = no
               LOCATE 23, 2: COLOR white, red: BEEP: PRINT "Update suspended, RADAR IS NOT TRACKING. Mode is "; Mode$;
       END IF
       IF RadarValid = yes AND DataPtr < Limit THEN
               DataPtr = DataPtr + 1
               WindPTR = DataPtr - 1
               OldPTR = DataPtr - 2
'get radar data
               FD!(Rng, DataPtr) = RangeRaw!
               FD!(Ele, DataPtr) = ElevationRaw!
               FD!(Az, DataPtr) = AzimuthRaw!
               FD!(Tm, DataPtr) = TimeRaw! + SampPeriod + 2
'calculate trig data
               FD!(Ht, DataPtr) = FD!(Rng, DataPtr) * SIN(FD!(Ele, DataPtr))
               FD!(Pl, DataPtr) = FD!(Rng, DataPtr) * COS(FD!(Ele, DataPtr))
               FD!(Th, DataPtr) = (((FD!(Pl, DataPtr) / 1000) ^ 2) / 16990) + FD!(Ht, DataPtr) + VAL(PreFlight$(2))
               FD!(PlotX, DataPtr) = FD!(Pl, DataPtr) * SIN(FD!(Az, DataPtr))
               FD!(PlotY, DataPtr) = FD!(Pl, DataPtr) * COS(FD!(Az, DataPtr))
               IF DataPtr > 1 THEN
                       FD!(Wh, WindPTR) = INT((FD!(Th, DataPtr) + FD!(Th, OldPTR)) / 2)
                       x! = FD!(PlotX, OldPTR) - FD!(PlotX, DataPtr)
                       y! = FD!(PlotY, OldPTR) - FD!(PlotY, DataPtr)
                       t! = FD!(Tm, DataPtr) - FD!(Tm, OldPTR)
                       FD!(Wv, WindPTR) = INT(SQR((x! ^ 2) + (y! ^ 2)) / t! * 10) / 10
                       IF y! = 0 THEN
                               y! = .000001
                       END IF
                       wdt! = ATN(x! / y!)
                       IF y! < 0 THEN
                               wdt! = wdt! + PI!
                       ELSE
                               IF x! < 0 THEN wdt! = wdt! + 2 * PI!
                       END IF
                       FD!(Wd, WindPTR) = (INT(fnDegs!(wdt!) * 10) / 10) / Deg2Rad!
                       IF FD!(Wh, WindPTR) > 2999 AND PreFlight$(5) = "15" AND TimeDone = no THEN
                               SampPeriod = 28
                               TimeChangeFlag = yes
                       END IF
                       IF FD!(Wh, WindPTR) >= LevelsHt!(Mb100PTR) THEN
                               TempValid = yes
                       END IF
                       IF WindPTR > 2 THEN
                               IF FD!(Wh, WindPTR) < FD!(Wh, WindPTR - 1) AND FD!(Wh, WindPTR - 1) < FD!(Wh, WindPTR - 2) THEN
                                       BurstFlag = yes
                                       TempValid = yes
                               ELSE
                                       BurstFlag = no
                               END IF
'phew!
                       END IF
               END IF
       END IF
       ClearStatus
END SUB
Tinine
Posted: 09:21am 06 Dec 2021
@CaptainBoing
I suspect that there's a miscommunication here (?)
QB64 is for windoze, Linux, etc. and has nothing to do with MS (and it's open-source)
I believe that MS QuickBasic only reached V4.5 and the PDS (professional development system) went to V7.1(?)
Posted: 09:45am 06 Dec 2021
oh right...
I was certain QB5 was a thing, but then I certainly remember QB45... I have no data either way so I yield - it is highly likely time has stewed my brain. To think about it, I think you are right and I am confusing things with VB5 which is where I engaged the Borg - my Wolf359.
still might port it just as an academic exercise - see what you started? Me looking at 35 year old code is more interesting than work
Edited 2021-12-06 19:49 by CaptainBoing
Tinine
Posted: 11:22am 06 Dec 2021
  CaptainBoing said  oh right...
Oh, I had to recently do the same thing for a client who wanted to switch a 3M/Microtouch monitor to an ELO-touch. Back in the late 80s, I hard-coded the serial-comms because the mouse-emulator driver was crap so now I needed to rewrite this for the ELO-touch.
Edited/compiled/linked using DOSBox in Windows and it was a fun task.
When I started with QB2, I came across a couple of performance bottlenecks due to MS wanting to preserve backward compatibility with BASICA. I discovered Crescent Software's "QuickPak" utilities that provided alternatives to QBs built-in functions. Crescent also included the full MASM source code and Crescent's owner, Ethan Winer, encouraged his customers to get into MASM, using his routines as templates. This made learning MASM quite painless and I really got into this stuff.
Posted: 12:27pm 06 Dec 2021
Hi Tinine,
Thanks for the trigger for QB64. Just tried the Win version on W10. It is fast. It solved the 4squares problem in below 1 ms (Yep, on a fast PC). That is 50000 times faster than an MM2.
And it can also work without line numbers, is auto indenting.
Now I need a comprehensive set of commands for USB serial port. Will do some investigating later today.
Confirm the delay with the first compile (maybe it is unpacking stuff first).
I downloaded the Linux(64) version also. Will try this tonight.
Edited 2021-12-06 22:31 by Volhout
Tinine
Posted: 03:38pm 06 Dec 2021
  Volhout said  Hi Tinine,
Oh cool beans I would like to follow your progress
Did a quick search and found this
