Local Time 07:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Missing Something Simple(PicoMite)
hitsware2
Posted: 10:53pm 04 Dec 2021
SETPIN pin, PWMnx Allocate pin to PWMnx
'n' is the PWM number (0 to 7) and 'x' and is the channel (A or B)
The setpin can be changed until the PWM command is issued. At that point
the pin becomes locked to PWM until PWMn,OFF is issued.
PWM channel, frequency,
[dutyA] [,dutyB]
PWM channel, OFF
There are 8 separate PWM frequencies available (channels 0 to 7) and up to
16 outputs with individually controlled duty cycle. You can output on either
PWMnA or PWMnB or both for each channel - no restriction.
Minimum frequency is 15Hz. Maximum speed is OPTION CPUSPEED/4
At very fast speeds the duty cycles will be increasingly limited
When I :
SetPin gp14,pwm7a
PWM 7,1000,50,50
I get :
[2] PWM 7,1000,50,50
Error : Pin not set for PWM
my site
panky
Posted: 02:43am 05 Dec 2021
@hitsware2
You are setting gp14 for use as PWM7a, yet in your pwm line, you try to set both the A channel and the B channel to 50 percent duty cycle but you haven't defined which pin to use for channel B.
If you are not using pin 20 (gp15) for anything else, adding the line SETPIN GP15,PWM7B should fix the problem or loose the second 50 in your PWM line.
Cheers,
Doug.
Posted: 02:48am 05 Dec 2021
From Picomite doc a28
"SETPIN 1,PWM0A    'Provisionally allocate pin 1 (GP0) to PWM0A
SETPIN 2,PWM0B    'Provisionally allocate pin 2 (GP1) tp PWM0B
PWM 0,1000,33,67  'Frequency is 1kHz for PWM0x, PWM0A is 33%, PWM0B is 67%
                 'The pins are now locked to PWM usage until PWM 0,OFF
PWM 0,OFF         'PWM0A and PWM0B are both off and the pins are released"
Could it be case sensitive?
I don't yet have one to try it.
Cross post . Ignore this.
Edited 2021-12-05 12:50 by phil99
hitsware2
Posted: 07:50pm 05 Dec 2021
  panky said  @hitsware2
Cheers,
Doug.
That did it ....
Thank You !
my site
