Local Time 07:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: What I'm I not seeing... :)
FeK9
Posted: 10:18am 04 Dec 2021
Have tinkered with Micropython and Arduino (MBED) on the Pi Pico.  A few days
ago I discovered PicoMite and MMBasic, I spent substantial hours on a Commodore 64
in the early 80's as a young adult and thought I'll give it a try... :)
I have few different versions of the RP2040, but the board I'm using at the mo is
the one from Cytron called 'Maker Pi Pico'...
From the PicoMite manual I got the SDCard working with the examples, and the
blinky Led example.  But the Play Tone example on pg 29 appears not to work. I
did switch to the MicroPython Demo by Cytron to be sure GP18 and GP19 where correct pins. Also checked it's schematic.
http://github.com/CytronTechnologies/MAKER-PI-PICO/blob/main/Out-of-the-box%20Demo%20Code/MicroPython/main.py
I've tried both stable and Beta versions of the firmware...
> list
Play TONE 500, 500
Pause 2000
Play TONE 300, 300
Pause 5000
> print MM.DEVICE$
PicoMite
> PRINT MM.VER
5.070108
> print MM.INFO$(SDCARD)
Ready
> OPTION LIST
OPTION SDCARD GP15
OPTION SYSTEM SPI GP10,GP11,GP12
OPTION Audio GP18,GP19, on PWM channel 1
Posted: 02:08pm 04 Dec 2021
Hi @FeK9 welcome onboard,
I have the same board, and I've tested and it doesn't work for me either.
I know that the firmware developer @matherp also has this board, but I think he is "on the road" at the moment. I suspect with a little patience either he or one of the other gurus will come back with an explanation for us.
Edited 2021-12-05 00:09 by thwill
Posted: 08:37pm 04 Dec 2021
Just tested on b6 and it work perfectly. Remember it is very high impedance so you need an amplifier - won't drive headphones
Also make sure the little switch points to the speaker with a cross (towards the audio jack). This disconnects the buzzer from GP18. On my board the buzzer is unusable and crashes the Pico - something wrong with the Maker Pi Pico circuit
FeK9
Posted: 02:25pm 05 Dec 2021
  matherp said  Just tested on b6 and it work perfectly. Remember it is very high impedance so you need an amplifier - won't drive headphones
Thx for reply
This is curious issue
The audio circuit works with Cytron's MicroPython Demo.
Scratch on these forums for b6 firmware you mentioned, found a b6 date July this year.
Loaded that but result is the same, no tone.
Had a close look pdf schematic of the 'Maker Pi Pico', seems to be a similar audio
circuit that is shown PicoMite manual. I'm also wondering if our board version differ,
mine is 1.2, it's next to the SDCard...
With my tests I've all ways used a powered external speakers, also my buzzer that is
attached GP18 is fine and given no problems...
For interest sake I nuke the Options List, then tried the pwm code shown below and
got a 'Middle C' tone. Tomorrow at the office I'll try a bare bone Pi Pico to see....
> PRINT MM.VER
5.070108
> setpin 25,pwm1b
> pwm 1,261.625,,50
Posted: 02:42pm 05 Dec 2021
Just tested again with b9 just posted and of course it works for me.
I assume PWM works on both GP18 and GP19?
What chip version are you using? Mine are all RP2-B1
Hate this sort of issue
FeK9
Posted: 03:05pm 05 Dec 2021
  matherp said  Just tested again with b9 just posted and of course it works for me.
Put bi nocks on and a bright light, I see it's marked RP2-B1...
I only tried pin 25 (GP19) with PMW...
FeK9
Posted: 03:54pm 05 Dec 2021
Success
I applied your suggestion of "Play volume 100,100" and it worked...
The pdf doc example on pg29 might need to be amended...
Thx
> option list
OPTION SDCARD GP15
> list
Play volume 100,100
Play TONE 500, 500
Pause 2000
Play TONE 300, 300
Pause 5000
> run
> PRINT MM.VER
5.070109
Posted: 04:05pm 05 Dec 2021
  Quote  I applied your suggestion of "Play volume 100,100" and it worked...
Should default to 100,100 on reset - the parameters are set to 100 in the variable initialisation - bizarre
Edited 2021-12-06 02:10 by matherp
FeK9
Posted: 11:30pm 05 Dec 2021
I've discovered what the issue is, no need for "Play volume 100,100".
Unlike when you add the two options to make the SDCard work and reboots it self,
adding the option "OPTION AUDIO GP18, GP19" does not cause a reboot. A Pi Pico reset
fix's the issue, I guess the options list needs to be reread again.
Thx's again... :)
