Forum Index : Microcontroller and PC projects : Two PicoMites on one PC?
| Calli Regular Member Joined: 20/10/2021 Location: GermanyPosts: 74 |
Solved! Maybe it is stupid Windows (10) but I can't connect two Picomites to one Computer via USB. Seperately they work, but seem to share one COM-Port, which I can change, but as soon I do it for one, Windows connects the same COM Port for the other one, so when I plug in both one is not given a Port... Windows can't differentiate the boards. EDIT: They are on the same USB-Hub. It seems it works when both are connected to a different Port/Hub on the PC... Still.. inconvenient.. EDIT EDIT: After I used them on different Ports/Hubs they suddenly work together! WINDOWS... I leave this here, maybe it is helpfull later. Any ideas? Carsten Edited 2021-12-04 00:26 by Calli |
| Kabron Regular Member Joined: 30/11/2017 Location: GermanyPosts: 65 |
It is also very annoying that pico constantly changes its port. |
Mine doesn't seem to. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Can't reproduce that. It may change (close to my problem) when changing which port it is connected to. C! |
