Local Time 07:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PCB for VGAmite?
     Page 1 of 4
Posted: 08:48am 29 Nov 2021
Seems to be lots of interest in the humble VGAMite so we certainly need a motherboard PCB.
Rather than lots of us doing our own variants it would make sense to have one person create a standard - who wants to volunteer?
My thoughts are to start with a specific box as this determines the size of the PCB. This one is both cheap and seems about the correct size but there are lots of different ones out there. Just needs to be something available worldwide and obviously the layout of the various connectors ultimately determine the size.
My spec would be as follows:
40-pin edge connector with 1-1 mapping of the Blackpill pins so that the pin numbering works on both
VGA connector with RGB selection as per one of the great ideas above
SDcard (fullsize to be easy to solder?)
battery holder for VBAT
PS2 connector
USB/UART (Microbridge to keep it through hole?)
Through hole USB-B for power/uart
On board components are minimal and can all be through hole - pullups to 5V for PS2 signal and data, VGA I/F, 2R2 and 10uF/0.1uF to condition power to SDcard, 100uF tank capacitor across incoming power.
Thoughts?
Edited 2021-11-29 18:52 by matherp
Posted: 09:09am 29 Nov 2021
Note the need to isolate a PS/2 pullup while programming/updating the firmware. The BOOT1 (PB2) pin has an onboard 10k pulldown so leaving the PS/2 pullup would put it into an indeterminate state.
Edited 2021-11-29 19:15 by Mixtel90
Posted: 09:22am 29 Nov 2021
  Quote  Note the need to isolate a PS/2 pullup while programming/updating the firmware.
Good catch Needs a jumper in the PB2 line
My recommendation for SD_CS would be PB1 which only loses PWM1C. This leave PA4 for the Flash chip.
Edited 2021-11-29 22:03 by matherp
Posted: 02:34pm 29 Nov 2021
  matherp said  we certainly need a motherboard PCB.
Nothing easier to solder or do layout for than this: micro sd card module
Posted: 03:24pm 29 Nov 2021
Nasty resistors just cause problems and aren't needed
Posted: 05:33pm 29 Nov 2021
Looks like a reasonable box - if you don't have to pay the stupid postal charges from the US. Similar box is available from China etc. There's even a UK source if you pay enough!  :)
Posted: 06:14pm 29 Nov 2021
Just an idea,
Could the PCB and connectors be arranged such that with some surgery (for the connectors) the VGAmite would fit in a standard Raspberry Pi 3/4 case and open up the possibility of putting it in a box with VESA mountings which could then be permanently mounted to the back of a compatible monitor to create and all in 1 (well 2 with the keyboard) unit ?
Posted: 06:35pm 29 Nov 2021
Vesa mounting only needs a strip of aluminium anyway. Personally I'd prefer to have a little extra room in the case than a RPi one, but YMMV. :)
flasherror
Posted: 08:08pm 29 Nov 2021
Thoughts?
Does the box dimensions permit an ESP8266 / HC12 / JDY40 RF module connector?
flasherror
Posted: 08:20pm 29 Nov 2021
  thwill said  Just an idea,
I like the idea reusing Pi cases, because long term availability of cases probably will not be an issue.
Not sure how you would fit a VGA DB15 connector in there!
Also, if using Pi cases and the motherboard has space, doing a partial subset (I2C/power) of the GPIO header would allow Pi GPIO modules (RTC, temp sensor, displays etc) to be easily used?
Edited 2021-11-30 06:27 by flasherror
flasherror
Posted: 08:43pm 29 Nov 2021
Isn't it easier to short/remove (whichever needed) the resistors rather than solder the SD card socket?
Turbo46
Posted: 01:17am 30 Nov 2021
I was going to suggest the case as used for the original mono maximite. It would be nice to acknowledge where it all began.
But I can only find it on the Altronics web site H0376  though.
Posted: 03:21am 30 Nov 2021
  Turbo46 said  I was going to suggest the case as used for the original mono maximite. It would be nice to acknowledge where it all began.
that would be cool
despite objections, i'd also back using an SD socket pre-assembled on a daughterboard from china, as this allows easy assembly by our (apparently) elderly forum members, no reason to not have it attached by flying wires.
peter: is there any (sensible) way to allow for a USB keyboard connected directly? ie, bitbanged at the lowest (1mb/s) USB speed.
rob   :-)
Edited 2021-11-30 13:22 by robert.rozee
Posted: 03:37am 30 Nov 2021
I volunteer, as I have already hinted at that in the other thread.
(that I am planning to do a mainboard for the VGAmite)
A full-size SD card socket is quite easy to solder, and everything else as through-hole was how I was planning to do things on my board.  I was planning to "Steal" phil99's bit of schematic and buffer the VGA output signal via his NPN emitter-follower idea, and three trimmers to set the individual RGB levels, giving maximum control over what colour you want.  I was not and am not planning to expand on that anymore then that - gotta remember the KISS method.
I had not considered fitting it to a case, but the same case as used for the CMM1 and CMM2 etc, is cheap, is available worldwide and would probably be what I would go for.
Would the members here agree that the BlackPill module should be socketed, or do the members think it would be better to solder it down to the mainboard?
I kinda like removable modules, as it is then much easier to plop another module in there if you suspect you have hurt the original module during some testing etc, and you don't then have to unsolder the old one.  Thoughts?
@ Bill: Re, the original Maximite case, yes, that is a good idea, and I think we'd get everything in there OK.  Has my vote.
Edited 2021-11-30 13:39 by Grogster
Cyber
Posted: 04:01am 30 Nov 2021
  Grogster said  Would the members here agree that the BlackPill module should be socketed, or do the members think it would be better to solder it down to the mainboard?
Socketed.
Turbo46
Posted: 04:25am 30 Nov 2021
Yes socketed please, I guess it could be assembled either way if you omit the sockets.
I do have concerns about Phil's circuit because it can stray a long way from the 75ohm input impedance of the monitor. Some monitors may not like it, there may be reflections and it may cause a fuzzy display.
Then again I may be talking out of my hat.
Posted: 07:16am 30 Nov 2021
OK then, socketed.
@ Turbo46: Can you suggest another circuit?  I hear what you are saying, but I was simply going to adopt phil99's circuit.
@ phil99: Can you comment on the above with respect to your arrangement?
Finally, only going to do the PCB if everyone else is happy that I do?
Posted: 07:52am 30 Nov 2021
For the colors on the VGA: use jumpers to select either
green = G only
white = R + G + B
amber = R + G
so in fact you can hardwire green, and then add red and blue as required.
-or- (that is quite oldschool) add 3 potmeters. so everybody can select their best rainbow color.
Edited 2021-11-30 17:54 by Volhout
Calli
Posted: 08:05am 30 Nov 2021
  [ said  QUOTE=Volhout
We can also wire it to a PWM Pin... :)
Posted: 08:06am 30 Nov 2021
Can't support the Altronics case as they seem to be the only supplier based on quick Google search and I think a case is a pre-requisite if this is to be a little "computer" so needs to be available worldwide
Rob: no idea if USB can be bitbanged and USB in general is something I have studiously tried to avoid - far too complex. Google returns lots of "is it possible" questions but no implementations.
Disagree with ESP socket. That sort of connectivity isn't the design brief for this port IMHO
Grogster: I'm definitely happy you do it assuming gerbers will be open source. Enjoy getting the pin mapping on the 40-pin edge connector right (remembering CMM2   )
Assuming space then I recommend using CR2032 battery holder as the batteries used on the CMM2 seem to be difficult to find in some locations
     Page 1 of 4
